scooby_doo_do Posted September 13, 2010 Share Posted September 13, 2010 At the weekend i decided to make the pond bigger in my new house... It's an old concrete thing that doesn't look like its ever been cleaned out. Since we've owned the house (november) we've not done anything too it. So i was slightly amazed when i found 13 fish in it, and about 10, 6" long muscles. I beleive the fish are just the basic goldfish type but have no idea. (biggest being 6" long, but they average i'd say 4") So i've stuck all them in a dustbin with a plant... question is, how long will they survice in there for? should they be ok? Going to be about 3/4 weeks until i get the liner in and can put them back. Thanks craig. Quote Link to comment Share on other sites More sharing options...
Martin J Posted September 13, 2010 Share Posted September 13, 2010 If you used the existing water from the pond, they should be OK for a while I'd imagine - although the bin probably isn't that large. When you put them back just make sure you're careful with the temperatures as too big a fluctuation and they'll not be too happy...! Quote Link to comment Share on other sites More sharing options...
scooby_doo_do Posted September 13, 2010 Author Share Posted September 13, 2010 yep - used exsisting water.. Quote Link to comment Share on other sites More sharing options...
ronttuk Posted September 13, 2010 Share Posted September 13, 2010 add air or they could suffocate a dustbin doesn't have much surface area Quote Link to comment Share on other sites More sharing options...
catfish man Posted September 13, 2010 Share Posted September 13, 2010 you need to get a air pump and air hose ,air stone ASAP just moving them is enough to stress them Quote Link to comment Share on other sites More sharing options...
fizzle Posted September 13, 2010 Share Posted September 13, 2010 put them in the bath and give em a bit more room!! Quote Link to comment Share on other sites More sharing options...
Thorin Posted September 13, 2010 Share Posted September 13, 2010 What size bin are we talking? Regular old style outside dustbin? I'd say they'd be fine, they're not very big fish. If they die just buy some more! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 13, 2010 Share Posted September 13, 2010 If its going to be 3-4 weeks i would bung an air pump on for good measure, and also do a small water change once a week. (edit) the reason for the water change is due to the build up of ammonia which the fish produce, as there is no form of filtration it will build up, and this will also have an overall effect on the oxygen retention of the water, hence the air pump, hope this helps explain things. Oh! and the mussels will die quite quickly with an ammonia build up. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 13, 2010 Share Posted September 13, 2010 I'd fry 'em. Goldfish are grand on toast. Quote Link to comment Share on other sites More sharing options...
Supra-Brett Posted September 13, 2010 Share Posted September 13, 2010 They should be fine as depth is OK, surface area is small though so oxygen transfer surface is hence small. Winter would be very bad in such conditions as the pretty much the whole surface of the in is above ground and although ice forms top down, it will form quicker and deeper. Add an oxygen pump in their for now to be sure they are OK, and use the same water too. Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted September 14, 2010 Share Posted September 14, 2010 Gold fish ara a hardy bunch, but as a minimum i would get an air stone in there, which will not only put oxygen into the water it will also circulate it too. If they wer koi you would most certainly be putting them under stress. What size pond ar you going for? Quote Link to comment Share on other sites More sharing options...
Rob Posted September 14, 2010 Share Posted September 14, 2010 Could you not build the "extension" to a nearly complete level with the fish still in the original pond, then transfer them to the bin for a week to perform the "breakthrough and connection works" thus minimising their time in a bin? Quote Link to comment Share on other sites More sharing options...
