Fitting rear window seal
evinX
Hi all, im having trouble fitting my rear windscreen seal, it has a lip that needs to clip onto the glass from the bottom, its a real pain to do! Being totally honest, removing and refitting the quarter glass were a breeze compared to this, any help would be great!
thanks, Kev
ok, this will be hard to explain here but the way i got the rubber lip under the glass was to feed the rubber into the window at a 90 degree angle to the glass to bend the rubber open and at the same time as pushing it into the window (very small amount at a time) i was twisting the rubber with the other hand over towards the glass to make the lip that goes under the glass bend downwards as it went in. really difficult to explain properly here but its a great way to do it (if you can understand what i'm trying to say) :)
