jackso11 Posted September 12, 2010 Share Posted September 12, 2010 (edited) I unplugged this today and the clip/plig on the wire fell to bits like the coil pack connectors do. Anyone got an idea of what the part number is? Edited September 14, 2010 by jackso11 (see edit history) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 14, 2010 Author Share Posted September 14, 2010 Anyone? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 14, 2010 Share Posted September 14, 2010 I have the number somewhere but I got two for Julian's car the other month, he still has a spare shell. E-mail him at [email protected] They were dear.... Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 14, 2010 Author Share Posted September 14, 2010 cheers chris. Any chance you can find the part number as Julian hasn't replied to my email and I need to get it on order tomorrow. By the way, brakes arrived thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 14, 2010 Share Posted September 14, 2010 90980-10737 or 90980-11062 They are both the same part. You can order new wire tails and pins, too, but I haven't access to the part numbers right now, they were about £9 EACH for the tails and pins though. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 14, 2010 Author Share Posted September 14, 2010 cheers chris. Are they similar to the coilpack clips to fit? Chris, do you know how to install the toyota parts catalogue? I have it but can't get it to work. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 14, 2010 Share Posted September 14, 2010 Yes. I have never got the EPC to install properly on my PC for years. The connector stuff isn't on it anyway. Even most UK dealers don't seem to have access to the drawings and part numbers, they deny they can be bought unless you cite an actual part number. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 15, 2010 Author Share Posted September 15, 2010 hmm, both parts a different prices. One is £9 and the second is £6. I went for the second one first Quote Link to comment Share on other sites More sharing options...
Steve Posted September 15, 2010 Share Posted September 15, 2010 Please update the thread when you get your connector, i need to replace my plug and pins for the coolant sensor Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 15, 2010 Author Share Posted September 15, 2010 Just searched for both part numbers and it seems they are the same but the different codes are for different colours. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 15, 2010 Author Share Posted September 15, 2010 confirmed.... http://toyota-corolla.ru/rm04f1ru/ewd/ewd/contents/connector/fig/ they are the same. Different codes = different prices and colours thats all Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 15, 2010 Share Posted September 15, 2010 When they arrived both were the same colour. Will try and update with the terminal repair kit part number later. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 25, 2010 Author Share Posted September 25, 2010 Right, it arrived, and its green. It is the 2 wire clip for one of the temp senders in the top rad pipe.....unfortunatly I need the 1 wire clip Any ideas what the part number for that might be? Its the plug that is right next to the 2 wire one. Also, I need the 2 wire sender itself....I bust mine getting it out the pipe not having much luck! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 (edited) The connector with two terminals is for the ecu to read the engine coolant temp. The single wire terminal is the sender for the dashboard coolant temp gauge. I have never had to buy either the sender or the connector, so don't know the part numbers. If you have the old connector to hand I can try and ID it off my Toyota wiring loom manual. I need crystal clear large format digital photos of the wire end and the sender end of the plug, taken square on, not something taken with a shaky hand with a camera phone! The sender part number should be available from any Toyota dealer given the VIN plate number, or maybe someone will look it up on their EPC for you. Edited September 25, 2010 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 Don't say I don't do things for you! I looked on a spare loom I have and the parts you need are: 90980-11428 Housing 82998-12440 Terminal (that's for a 160 mm long piece of wire with one terminal attached as a repair section for the loom if needed). Quote Link to comment Share on other sites More sharing options...
Steve Posted September 25, 2010 Share Posted September 25, 2010 Chris, that terminal 82998-12440, is that the same pin that is used on all the other connections. ie. coolant temp sender (ecu), coil packs etc Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 25, 2010 Author Share Posted September 25, 2010 Thank chris! you are a star. The housing is the clip for the single wire sender right? I think I will need a new sender for the ecu (the two wire one) as the plug bust off the back of it. Is that the other part number? I will get photos up of my problems Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 Chris, that terminal 82998-12440, is that the same pin that is used on all the other connections. ie. coolant temp sender (ecu), coil packs etc It's used in quite a lot of connectors, but not all. It's definitely the same terminal for the coil packs. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 Thank chris! you are a star. The housing is the clip for the single wire sender right? I think I will need a new sender for the ecu (the two wire one) as the plug bust off the back of it. Is that the other part number? I will get photos up of my problems I thought you'd already bought the ecu sender connector shell? The last part numbers I posted about are for the single terminal sender, for the gauge, and for one wire repair lead. Quote Link to comment Share on other sites More sharing options...
Steve Posted September 25, 2010 Share Posted September 25, 2010 It's used in quite a lot of connectors, but not all. It's definitely the same terminal for the coil packs. How about the water temp sender for the ECU? Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 25, 2010 Author Share Posted September 25, 2010 I did buy the ecu connector, but the other part has now broken off the sender itself, see pic. These are the two senders. I need the plug for the end of the wire to plug into the one on the left, and now I need a new ecu sender as you see from the picture this one is broken in half. I have the plug for the wire to plug into that one. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 I am pretty sure they are same terminal repair kits Steve, yes. These numbers may help someone searching here: 90980-10947 Housing Crank position sensor 90980-11144 Housing IACV 90980-11349 Housing Alternator 90980-10845 Housing MAP 90980-11062 Housing Coolant ECU 90980-11428 Housing Coolant Gauge Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 25, 2010 Share Posted September 25, 2010 I did buy the ecu connector, but the other part has now broken off the sender itself, see pic. These are the two senders. I need the plug for the end of the wire to plug into the one on the left, and now I need a new ecu sender as you see from the picture this one is broken in half. I have the plug for the wire to plug into that one. You need 90980-11428 Housing I don't have the part number for the sender unit. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 25, 2010 Author Share Posted September 25, 2010 when you say housing, do you mean they are all the plastic plug/housing on the end of the wires that plug in to each of those? Useful list of that is what they are So you have the part number for the temp sender? I am going to have a go at installing the toyota parts catalogue again later so if I get that working I will put a guide up. edit... Ahh, you answered as I was typing Quote Link to comment Share on other sites More sharing options...
Steve Posted September 25, 2010 Share Posted September 25, 2010 I did buy the ecu connector, but the other part has now broken off the sender itself, see pic. These are the two senders. I need the plug for the end of the wire to plug into the one on the left, and now I need a new ecu sender as you see from the picture this one is broken in half. I have the plug for the wire to plug into that one. I may have a spare Water temp sender in the shed will have to check, will swap for the 2 wire clip you bought in error Failing that IIRC the part number is stamped on the side of the sender I am pretty sure they are same terminal repair kits Steve, yes. Thanks Chris Quote Link to comment Share on other sites More sharing options...
