eu spec camshaft
needy
hallo guyes
I've mounted eu camshaft in my jap spec engine. I've have not made otherwise than mounted in the engine, can that be the reson that there comes a knoking in the engine when the oil starts to warm, because the valve not adjusted into the camshaft????
the knocking starts at 2500 rpm. it sounds a bit like a rod knocking. but it cant be because the bottom has new head and rod bearings.
hallo guyes
Did you check the valve clearance when you put the cams in.
