Supragal Posted June 10, 2005 Share Posted June 10, 2005 I was under the impression that clutches slipped when they were on their way out? Do they sometimes not? Symptoms I have are: - Car pops out of gear sometimes, usually reverse - Pull away with any force and the car lurches as it gets to biting point - Squeels (presumably bearing) when biting point engages - The second biting point engages the revs drop as the car moves away - Very small biting point (if that makes sense) - Clutch pedal is really stiff and creaky and lumpy Thoughts please? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 10, 2005 Share Posted June 10, 2005 is this the supra? if so how many times it been driven since? as it has been sat for very long time! Quote Link to comment Share on other sites More sharing options...
Alex Posted June 10, 2005 Share Posted June 10, 2005 ...could be whole host of things...inc the gearbox itself Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 10, 2005 Share Posted June 10, 2005 It's the crappy Rover isn't it I remember saying that clutch was on the way out over a month ago The squealing is probably metal-on-metal instead of friction-material-on-metal -Ian Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 10, 2005 Share Posted June 10, 2005 I was under the impression that clutches slipped when they were on their way out? Do they sometimes not? Symptoms I have are: - Car pops out of gear sometimes, usually reverse - Pull away with any force and the car lurches as it gets to biting point - Squeels (presumably bearing) when biting point engages - The second biting point engages the revs drop as the car moves away - Very small biting point (if that makes sense) - Clutch pedal is really stiff and creaky and lumpy Thoughts please? I think mine was on its way out but i get different symptoms to yours. Only in 3rd or 4th gear if driving along steady then foot on floor revs build to 4,000 rpm then due to 2nd turbo revs shoot round to 5,000 then i assume the clutch grips again revs go back to 4,500 then build up again. doesn't happen when booting it from 1st gear onwards, just when cruising in 3rd or 4th !??! Quote Link to comment Share on other sites More sharing options...
Supragal Posted June 10, 2005 Author Share Posted June 10, 2005 Guys, if it was Supe related wouldn't you think that a) It's be in the Supra tech section and b) You'd have heard me going on about the fact it's back on the road. Ian, yes of course it is. But I don't want to replace the clutch to find out it's the box, especially as they are reknown for box probs. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 10, 2005 Share Posted June 10, 2005 good point ! i had to replace a gearbox on a fiesta i owned many moons ago cos under load it popped out of gear - but hey it was a ford ! Quote Link to comment Share on other sites More sharing options...
BigRoy Posted June 10, 2005 Share Posted June 10, 2005 It's the crappy Rover isn't it I remember saying that clutch was on the way out over a month ago The squealing is probably metal-on-metal instead of friction-material-on-metal -Ian what he said Quote Link to comment Share on other sites More sharing options...
Supragal Posted June 10, 2005 Author Share Posted June 10, 2005 Okayyyyyyyyyyyyyy so what other symptoms would I be expecting if it is the box? Which if the above tie up with it being box/clutch Quote Link to comment Share on other sites More sharing options...
BigRoy Posted June 10, 2005 Share Posted June 10, 2005 I still reckon its the clutch Rosie. The jump out of gear could be fork selector problem but seeing as you have clutch issues:D I'd bet on that. Cant be much for a new plate but by the sound of it you may need the flywheel skimmed. Bung Ian a fiver he will fit it for you:D Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 10, 2005 Share Posted June 10, 2005 Haha fuck off, I only work on proper cars Quote Link to comment Share on other sites More sharing options...
BigRoy Posted June 10, 2005 Share Posted June 10, 2005 I reckon its got jealous cos the purple thingy might be ready within the next 36 months and it knows its days are numbered:D Quote Link to comment Share on other sites More sharing options...
Supragal Posted June 10, 2005 Author Share Posted June 10, 2005 Ok I guess I need to take it somewhere to confirm, or sell it Quote Link to comment Share on other sites More sharing options...
tDR Posted June 10, 2005 Share Posted June 10, 2005 Judder on clutch engagement is usually the fingers on the clutch cover plate... they get fatigued with mileage and become sticky. Clutches don't always slip - I had a complete failure of the clutch on my 200SX but then I was drifting it at the time and clutch kicking which shattered the friction material Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
Supragal Posted June 12, 2005 Author Share Posted June 12, 2005 It doesn't judder. It's kinda difficult to explain. It's really on or off, no in between. The actual pedal is sticky and lumpy not the engagement. Quote Link to comment Share on other sites More sharing options...
Gordon F Posted June 12, 2005 Share Posted June 12, 2005 Put a new clutch cable on it. Will probably cost less than £10. It may not improve things, but for a tenner you may as well try it. Quote Link to comment Share on other sites More sharing options...
Graham S Posted June 12, 2005 Share Posted June 12, 2005 sounds like the clutch, every shed, sorry rover i've had in with box/clutch problems has pretty much always been the diff thats gone, so you'd be hearing a humming noise when you drive it, and your symptoms sound like the clutch, bit of piss to do, so not to expensive.. Quote Link to comment Share on other sites More sharing options...
Graham S Posted June 12, 2005 Share Posted June 12, 2005 still a rover though, so is it worth it lol!! Quote Link to comment Share on other sites More sharing options...
Supragal Posted June 13, 2005 Author Share Posted June 13, 2005 Humming noise you say? So, err, Graham, wanna take a look for me? Quote Link to comment Share on other sites More sharing options...
Guest chiefvinso Posted June 23, 2005 Share Posted June 23, 2005 How about the clutch cable? Quote Link to comment Share on other sites More sharing options...
Guest chiefvinso Posted June 23, 2005 Share Posted June 23, 2005 Whooprs cable already mentioned. Quote Link to comment Share on other sites More sharing options...
