Immboliser problem
Kazuma
Hi guys got myself a little problem, hopefully you may be able to help. I have a Sigma S30 alarm/immobiliser installed. I mistyped the code and no my car won't start! I've tried waiting for 30 seconds before retyping the correct code and still nothing. I even locked the car, got back in and then tried again to no avail...
Does anyone know of an override or basically what i should try next. I tried to ring the company that installed it but it seems to be a fax number. Unfortunately this was installed before I got it..:(
Just called Scorpion Autos.com - NB if anyone else has a similar problem, this is the temporary way of starting the car.. you'll still need to get the device sorted out. Also worth noting, i've not tried this yet, so they may have just lied to me :hang:
Anyway what to do:
1. Get in car and locate led on dashboard
2. Put key in ignition and turn on then off
3. Turn back on and then off
4. Turn back on, this time count how many flashes appear on the red led on dashboard. Turn to the off position on the corresponding flash. i.e. if code was 2345 wait until you see the second flash then turn the ignition to off.
5. repeat until you've effectively entered the pin. The car should start at this point.. or so I was told.
BTW, I went home and tried this however, I then realised that may battery is flat!! So will get a new battery, not messing around charging it. Will post what happens after I fit the new battery.. hopefully, I'll be able to type the code and it'll start first time!
  • 4 months later...
Anyway what to do:
hello mate
can resolve the alarm problem?
I have the same problem with my car will not start and after 3/4 times the push button, the car starts....
you imagine when i take fuel ...
i have a little plate whit 5 number ,and stange little key to action something in the alarm,but nothing happens
help me please ;)
a++
  • 1 month later...
Sorry for not replying, been a bit hectic over here. I don't fully understand your problem.. I would however suggest giving Scorpion Automotive a ring on 01257 249928.
However, by the date of your post you probably have sorted it already!
