colmcork Posted September 11, 2010 Share Posted September 11, 2010 After a lot of searching guys i still haven't found an answer to this one. My problem is that i cannot see how to remove the plastic ''surround'' that keeps the factory sub in position as there are two wires running through it and down to the rear hubs. Is there somewhere to easily un-clip these two wires or will i have to cut this plastic surround to get it removed? Any help guys is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 11, 2010 Share Posted September 11, 2010 it has its own plug connector. Quote Link to comment Share on other sites More sharing options...
colmcork Posted September 11, 2010 Author Share Posted September 11, 2010 it has its own plug connector. I think you might be on about the actual sub itself, which indeed does have it's own connector. This was very simple to undo. The two wires i am on about however are running through the plastic casing and down through the body of the car and onto the rear hubs. I think they might be abs sensors?? Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted September 11, 2010 Share Posted September 11, 2010 They are ABS sensors. If you follow the wires back inside the car about a foot you can unplug them. Quote Link to comment Share on other sites More sharing options...
colmcork Posted September 11, 2010 Author Share Posted September 11, 2010 Excellent stuff thanks mate. Got this sorted out. A bit of a PITA taking off the trim panels just to unclip these. Quote Link to comment Share on other sites More sharing options...
