UK spec turbo's complete with manifolds.
little num
Hi all i bought these a few weeks back to use a project, i was going to fit them onto my 1JZ engine but when it came down to it i started to look at how different they are compared to the CT12A soarer turbo's.
So after a long think i have decided to go hybrid with the CT12A so these are no longer needed.
I have had them inspected by DOUGSPORT and he says they are mint, have came off a UK AUTO with 100 thou and feel nice.
I paid extra for the manifold and obviously had them checked by my turbo man.
So i think £250 collect or £265 posted within the uk is a cracking buy.
These will fit onto the 2JZ head but not the 1JZ head, and dont forget these are steel internals so can handle 1.3 - 1.4 allday long.
hey all right there is very minimal play (up and down) but there should be to allow the oil to flow around the bearing, there no NONE forwards and backwards.
I had them checked by DOUGSPORT who around the midlands is very well known to be a great turbo specialist.
He had them for 3 hours and called to say they are mint with no wear on the bearing housings at all, but unfortunatly i hadent tried them for size so they have to go.
My number is 07809 627560 cheers james.
As for fitting to jspec im not 100% sure but i think they are the same bolting patterns and the pipe's are the same size, but if any1 else could give more info that would be a big help.
  • 3 months later...
