New Exhaust!
Guest Usmann A
Guest Usmann A
Hi Guys!
I thought id get some valueble advice from the forum crowd!
Bsaically "nana"at option said that the super drager i have on the car is not as freeflowing as other exhausts,due to when i reach a certain level of tune the exhaust can be restrictive.
But which exhaust should i use,i like the 95mm pipework of the drager and its 130mm tip.
I was suggested a blitz nur spec,but also looked at the hks titanuim, they pipework im unsure about,i think its smaller than the drager but the drager is is just huge.
Which is the best exhaust or shall i say the best exhuast without spending a grand on it.
Any help will be appreciated!
Cheers!
HKS Hipers are the straightest....
But the drager will be fine for pretty much anything you can throw at it....
If you want to release restriction get it Decatted.
Chris Wilson (search for his name for his contact details) has decat pipes just the right size to keep the boost down but also reduce lag and up the power.
Guest Usmann A
Cheers!
Guys i need tyres,i raced a 330ci from the lights and kept on bloddy goin sideways.So the tyres a worn.Which r the best pls uregnt help.
Thanks in advance!
Originally posted by usmann_a
Cheers!
Thanks in advance!
Allot of the guys on here use Bridgstone (SO2 & SO3) or the goodyear F1's.
I have Khumo tyres on my Supra (Came on the car). They are one of the better budget tyres and to be honest i have found them OK. I guess it depends on the budget you have, In the long run the Goodyear and Bridgstone will probably pay for themselves when it comes to a sliding moment.
