Crockett512 Posted September 7, 2010 Share Posted September 7, 2010 Nipped down the garage for some petrol, thought it odd someone was flashing me... got back home (5min drive each way) and noticed a kind off whistling sound.... and steam.... checked my levels, tiny amount in the resevoir, and the rad took 1.5 jugs full! I'm hoping this is the cause of the steam, not BHG or thermostat. I find it strange that the gauge in the car didn't throw up a warning?? It normally rises to mid gauge quickly and stays there. Hopefully (for me) this is just a nice reminder... on a long journey it could have been fatal for the engine! Link to comment Share on other sites More sharing options...
imi Posted September 7, 2010 Share Posted September 7, 2010 why was it so low - surely that is not normal and worth investigating? Link to comment Share on other sites More sharing options...
Kirk Posted September 7, 2010 Share Posted September 7, 2010 If you have lost that much water then you have a problem on your hands Link to comment Share on other sites More sharing options...
Crockett512 Posted September 7, 2010 Author Share Posted September 7, 2010 I'll hold my hands up and say that I don't know when I last checked the level, I'll drive it to work armed with a bottle of water and see how I go. Steam seemed to be emanating from the front, not the engine area, so at worst a split rad? Whilst topping it up I couldn't see any leaks, and I let it idle for a while and didn't notice any steam after filling up... Link to comment Share on other sites More sharing options...
Purity14 Posted September 7, 2010 Share Posted September 7, 2010 Could be rad cap. Link to comment Share on other sites More sharing options...
jazz1 Posted September 7, 2010 Share Posted September 7, 2010 You might have a hair line crack leep found one in mine Link to comment Share on other sites More sharing options...
Crockett512 Posted September 7, 2010 Author Share Posted September 7, 2010 You might have a hair line crack leep found one in mine In the rad? not so bad if that is the case... Link to comment Share on other sites More sharing options...
jazz1 Posted September 7, 2010 Share Posted September 7, 2010 In the rad? not so bad if that is the case... Yea so he replaced it with koyo rad Link to comment Share on other sites More sharing options...
Robzki Posted September 7, 2010 Share Posted September 7, 2010 Not wanting to state the obvious, and not saying you did, but cold water in hot engines isn't a good idea, just for clarity. Hope this is taken as intended Rob Link to comment Share on other sites More sharing options...
Crockett512 Posted September 8, 2010 Author Share Posted September 8, 2010 Not wanting to state the obvious, and not saying you did, but cold water in hot engines isn't a good idea, just for clarity. Hope this is taken as intended Rob Sound advice! and yes I did let it cool for an hour or so before I played around. Update: Filling it up last night proved fine on the drive to work today, so 'hopefully' the level was just too low in the resevoir. I'll be draining the system, replacing rad hoses and cap and refilling with coolant this weekend seeing as I've just put water in there as a temporary fix... hopefully got away lucky with this one! Link to comment Share on other sites More sharing options...
monsween Posted September 8, 2010 Share Posted September 8, 2010 I always have some coolant in my car ready incase it gets low. That an engine oil and gearbox oil lol. Link to comment Share on other sites More sharing options...
Crockett512 Posted September 8, 2010 Author Share Posted September 8, 2010 I always have some coolant in my car ready incase it gets low. That an engine oil and gearbox oil lol. Where do you put them, there's no room as it is?! I can't even stand a carton of milk up straight in the boot of mine Link to comment Share on other sites More sharing options...
monsween Posted September 8, 2010 Share Posted September 8, 2010 Lie them down on each other at a jaunty angle. None of them have ever leaked on me........... yet lol And yes they are all 5litre bottles Link to comment Share on other sites More sharing options...
supraman382 Posted September 8, 2010 Share Posted September 8, 2010 Thermostat stuck shut and engine overheated 'pushing' it back out through the reservoir? Link to comment Share on other sites More sharing options...
L18msy Posted September 8, 2010 Share Posted September 8, 2010 I check my levels every week or so just to be sure. Link to comment Share on other sites More sharing options...
Crockett512 Posted September 9, 2010 Author Share Posted September 9, 2010 Thermostat stuck shut and engine overheated 'pushing' it back out through the reservoir? Possibly, though since I topped it up it's been fine, and the gauge in the dash never read high? Seems very odd. I'm changing the stat, cap, bottom and top hoses this weekend and replacing the coolant as it's not going to do any harm! Link to comment Share on other sites More sharing options...
