BW turbo oil feed thread size
David Reid
This fitting is on a BW 300SX series turbo?
Pics as below
Does anyone know what type of fitting it is?
Or waht thead size it is?
I have rung Paul and Whiff bits and he cant remeber and also doesnt have any line in stock.
I am going to have a new line made with dash 3 fitting but dotn know what this fitting is, can anyone help?
Thanks for the advise, I searched other forums for posts by Jeff from full race posts on and found this advise on the GTR forum which will be good for anyone else needing this info.
Quote from Jeff @ fullrace
"regarding the fitting, simply remove the fitting that comes with the BW turbos ( i dont know why they include them at all) and simply insert a 1/4" NPT male thread. normally we recommend using a 1/4" NPT male to 1/8" NPT female and then you can use a -3AN male to 1/8" NPT male. NEVER EVER use -4AN for an oil feed on GT Ball bearing turbos OR BW Turbochargers. if you do, it will require a restrictor to .050" or 0.035" or you will burn some oil as it slips past the turbine seal."
