Tyson Posted September 6, 2010 Share Posted September 6, 2010 There is a leak from the rear drivers side brakes, don't know if its the caliper or the lines but what kind of prices should I be expecting for either? If its a split hose is it worth upgrading to braided hoses all round ? What make do people recommend ? How much money will a set cost? Thanks in advance. Link to comment Share on other sites More sharing options...
merckx Posted September 7, 2010 Share Posted September 7, 2010 The Goodridge hoses appear to be the most popular, stock hoses from Toyota cost a lot more. You can get them with zinc plated end fittings or stainless steel. I'm going to get them from this seller on ebay. http://shop.ebay.co.uk/jwracing777/m.html?_nkw=GOODRIDGE+BRAKE+LINE+KIT+TOYOTA+SUPRA+JZA80&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313 Link to comment Share on other sites More sharing options...
4packet Posted September 7, 2010 Share Posted September 7, 2010 Why not take the wheel off and establish the issue first? Tightening the banjo bolt may fix the issue if the leak is between the 2 components you've convinced yourself need replacing. Link to comment Share on other sites More sharing options...
fastcar Posted September 7, 2010 Share Posted September 7, 2010 yep definetly have a look first and see what the problem is. if you do find its the brake pipe leaking then i would definetly recommend getting Goodridge braided hoses. Have them on my car and definetly give a better brake feel. Probley worth doing anyways. Link to comment Share on other sites More sharing options...
Tyson Posted September 7, 2010 Author Share Posted September 7, 2010 going to pop the wheel off tomorrow to have a look and see where the leak is coming from. Link to comment Share on other sites More sharing options...
Tyson Posted September 7, 2010 Author Share Posted September 7, 2010 The Goodridge hoses appear to be the most popular, stock hoses from Toyota cost a lot more. You can get them with zinc plated end fittings or stainless steel. I'm going to get them from this seller on ebay. http://shop.ebay.co.uk/jwracing777/m.html?_nkw=GOODRIDGE+BRAKE+LINE+KIT+TOYOTA+SUPRA+JZA80&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313 So this kit will replace all the rubber hoses right? As I read most of these kits only change the hoses between the hard pipe and the caliper meaning there is still some rubber hoses and you won't get the full effect of the upgraded lines. Or am I talking complete crap ? Link to comment Share on other sites More sharing options...
dude Posted September 7, 2010 Share Posted September 7, 2010 So this kit will replace all the rubber hoses right? As I read most of these kits only change the hoses between the hard pipe and the caliper meaning there is still some rubber hoses and you won't get the full effect of the upgraded lines. Or am I talking complete crap ? There are no other rubber hoses dude;) Link to comment Share on other sites More sharing options...
Tyson Posted September 7, 2010 Author Share Posted September 7, 2010 There are no other rubber hoses dude;) Link to comment Share on other sites More sharing options...
Robzki Posted September 7, 2010 Share Posted September 7, 2010 Do-luck ones were about £60 for a full set with stainless fittings(a must imo) not a pretty colour(purple kinda) but pedal is a lot firmer, loses a lot of the spongey feel. Also any rubber parts on the car at anything up to 17yrs old will have started to perish/degrade in some way so a worthwhile upgrade. Also while you are working on the brakes have a look at the steel pipes that run under the car surrounded by plastic trim. especially just above the fuel tank, hidden under a small cover held on with a 10mm bolt, takes 5-10mins to remove covers and check. You may be worried/concerned/miffed at what you find. Link to comment Share on other sites More sharing options...
Tyson Posted September 7, 2010 Author Share Posted September 7, 2010 Do-luck ones were about £60 for a full set with stainless fittings(a must imo) not a pretty colour(purple kinda) but pedal is a lot firmer, loses a lot of the spongey feel. Also any rubber parts on the car at anything up to 17yrs old will have started to perish/degrade in some way so a worthwhile upgrade. Also while you are working on the brakes have a look at the steel pipes that run under the car surrounded by plastic trim. especially just above the fuel tank, hidden under a small cover held on with a 10mm bolt, takes 5-10mins to remove covers and check. You may be worried/concerned/miffed at what you find. I've just read the stickied thread about the 15 year old rotted hard pipes that live under the cover. It's going up on a lift so will have a look there too !! Thanks for the head up anyway !! Link to comment Share on other sites More sharing options...
Robzki Posted September 7, 2010 Share Posted September 7, 2010 nps, was on my mind as I've had an mot advisory on mine and had a good look over them today the only bits that were 100% ok were the bits under said plastic mud/water trap ..... under the other covers they are 90% with only a little white dust/corrosion. The worst parts were as they leave the long plastic cover and start to head up over the subframe....not great but ok to clean and protect now. good luck Link to comment Share on other sites More sharing options...
Tyson Posted September 8, 2010 Author Share Posted September 8, 2010 well scrap everything I have said had it up in the air and I didn't know the oil cooler for the diff was on that side and my trusted mechanic (been with for ages, friend of the family) says that it looks more like that but he can't tell yet until he has a better look whether its just a split pipe / seal or something else. Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 8, 2010 Share Posted September 8, 2010 It will almost certainly be a rusted through steel pipe under the cover. They aren't very dear to replace, or you can bypass the diff cooler altogether if you are really on a tight budget. It probably never gets hot enough to work, unless you do track days, and may even be seized up anyway. SOMETHING needs doing ASAP though. Link to comment Share on other sites More sharing options...
Dnk Posted September 8, 2010 Share Posted September 8, 2010 My diff cooler fell to pieces at the end of last year, the pipework was actually ok so i looped it back on itself untill i fit the new cooler. All the pipe work and cooler comes to a quite a few £'s if you buy the parts from Toyota !! Link to comment Share on other sites More sharing options...
Tyson Posted September 9, 2010 Author Share Posted September 9, 2010 not on a tight budget it turned out to be a pipe rather than the cooler itself. I took the opportunity to replace all the pipes for peace of mind. Link to comment Share on other sites More sharing options...
Tyson Posted September 9, 2010 Author Share Posted September 9, 2010 My diff cooler fell to pieces at the end of last year, the pipework was actually ok so i looped it back on itself untill i fit the new cooler. All the pipe work and cooler comes to a quite a few £'s if you buy the parts from Toyota !! yes it does !!!!! Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 9, 2010 Share Posted September 9, 2010 not on a tight budget it turned out to be a pipe rather than the cooler itself. I took the opportunity to replace all the pipes for peace of mind. No offence meant, it's just that the differential cooler is a bit OTT for most owners. Link to comment Share on other sites More sharing options...
Tyson Posted September 9, 2010 Author Share Posted September 9, 2010 No offence meant, it's just that the differential cooler is a bit OTT for most owners. I like keeping everything working even if I don't need it as I am like that. Everything has to be perfect hence I always have something to do No offense taken Link to comment Share on other sites More sharing options...
Dnk Posted September 9, 2010 Share Posted September 9, 2010 Very supprised your cooler is okay, mine was totally scrap and fell apart on removal. Link to comment Share on other sites More sharing options...
Tyson Posted September 10, 2010 Author Share Posted September 10, 2010 Very supprised your cooler is okay, mine was totally scrap and fell apart on removal. I think its all to do with have the car has been used. The car has been garaged just about all of its life and mostly only taken out on dry weather so it hasn't been subject to much weathering. The cooler itself was in pretty good condition despite its age. I mean it might have already been replaced but I have yet to find a receipt to prove this. Link to comment Share on other sites More sharing options...
Dnk Posted September 10, 2010 Share Posted September 10, 2010 Yes driving in all sorts of crap weather probably killed mine, its not exactly the best place for it either and the plastic cover doesnt stop it getting covered in rd muck. Link to comment Share on other sites More sharing options...
Tyson Posted September 10, 2010 Author Share Posted September 10, 2010 Yes driving in all sorts of crap weather probably killed mine, its not exactly the best place for it either and the plastic cover doesnt stop it getting covered in rd muck. I don't think Toyota ever planned for them to last this long so stupid covers like this were probably overlooked in the way that they assumed by the time it became a problem the car would be in a scrapyard anyway. Link to comment Share on other sites More sharing options...
