ManwithSupra Posted June 9, 2005 Share Posted June 9, 2005 Ok i am a new supra owner and still on a great big learning curve. On my 3ltr tt auto it has a Manu Button ??? What is this and how do you use it ?? Quote Link to comment Share on other sites More sharing options...
Conrad Posted June 9, 2005 Share Posted June 9, 2005 Ok i am a new supra owner and still on a great big learning curve. On my 3ltr tt auto it has a Manu Button ??? What is this and how do you use it ?? I don't know for sure but I'm sure somone will tell you, but in that mode each particular selection ie Drive, Neutral etc acts as a gear where by you can drive it as a manual. Albeit with three gears. Although I stand to be corrected.... Quote Link to comment Share on other sites More sharing options...
Class One Posted June 9, 2005 Share Posted June 9, 2005 It allows gear hold, very good for 3rd gear country lane blasting around 4000rpm so tubby 2 is available when you floor it. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 9, 2005 Author Share Posted June 9, 2005 Thanks thats brill, How about the little red button with the japaneese writing underneath it ?? Quote Link to comment Share on other sites More sharing options...
Stonkin Posted June 9, 2005 Share Posted June 9, 2005 The red button allows you to move the car when it is not started. Basicly you cant take the car out of 'park' if the engine is not running. This is useful if for example the battery is flat Christian Quote Link to comment Share on other sites More sharing options...
TrevS Posted June 9, 2005 Share Posted June 9, 2005 I had the same problema few weeks ago trying to work out how the manual mode works. You can press the manu button and manu mode should light up on the dash. Now the car is in manual mode you can can keep the car in gear longer and redline it. L = 1st gear 2 = snd gear D = 3rd gear This manu mode also makes gear changes quicker. One other thing I think is that in manu mode you can't get the car into four so its not one for the motorways. You should really just use the manu mode for blasting around country lanes and the like. when you need to come out of manu mode just press the manu button again, simple. Hope this helps. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted June 10, 2005 Share Posted June 10, 2005 I had the same problema few weeks ago trying to work out how the manual mode works. You can press the manu button and manu mode should light up on the dash. Now the car is in manual mode you can can keep the car in gear longer and redline it. L = 1st gear 2 = snd gear D = 3rd gear This manu mode also makes gear changes quicker. One other thing I think is that in manu mode you can't get the car into four so its not one for the motorways. You should really just use the manu mode for blasting around country lanes and the like. when you need to come out of manu mode just press the manu button again, simple. Hope this helps. Just click Manual mode back off when you want 4th.....thats what I do?? make dure overdrive is in though Quote Link to comment Share on other sites More sharing options...
