Guest supersupra93 Posted September 6, 2010 Share Posted September 6, 2010 hello i have a 1993 n/a auto supra that has about 185k miles car was running great until a few weeks ago where the car would start run for a couple seconds then die...i tried replacing tps (throttle position sensor) but did not help....now whats really getting me is this isn't a consistent problem...it just happens at random times if anyone has any ideas what it coulb be really helpfull.... Quote Link to comment Share on other sites More sharing options...
robin Posted September 7, 2010 Share Posted September 7, 2010 Are you getting any error codes? Quote Link to comment Share on other sites More sharing options...
dude Posted September 7, 2010 Share Posted September 7, 2010 Try putting a 12v feed to the fuel pump, it may be losing its feed as the car starts, ie there is enough to prime the system but not to run it. Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 7, 2010 Share Posted September 7, 2010 Clean Idle control valve and check fuel filter. Quote Link to comment Share on other sites More sharing options...
Shane Posted September 7, 2010 Share Posted September 7, 2010 Mine did exactly this and if I gave the fuel pump constant feed it as Dude has said it ran ok. Also with mine the engine management light didnt come on. After ripping the car to bits as I suspected the imobilliser, it turned out that a loose battery connection had killed my ECU. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 7, 2010 Share Posted September 7, 2010 As above, fuel pump ECU on its way out Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted September 7, 2010 Share Posted September 7, 2010 As above, fuel pump ECU on its way out Ed Morris should have a spare one of these Quote Link to comment Share on other sites More sharing options...
Guest supersupra93 Posted September 8, 2010 Share Posted September 8, 2010 i am not getting any error codes...and not to seems slow but how would i go about putting a 12v feed to the fuel pump? and i did have a lose negative terminal at one time but i replaced it i dont think my ecu is gone because the problem is not consistent because i was able to start and run it yesterday but i wasnt brave enough to drive it(was scared i might get stranded somewhere lol) but am i wrong? is there a possiability that it is my ecu? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 9, 2010 Share Posted September 9, 2010 +B to FP connections of the diagnostic port on the engine (i.e. voltage fed to the pump all the time the ignition is on). Quote Link to comment Share on other sites More sharing options...
Guest supersupra93 Posted September 9, 2010 Share Posted September 9, 2010 ok my car was running and driving fine earlier today then i turned the car off to do some stuff and it started stalling when i started it....so i did the 12v thing and started it right up and it ran perfect...does this mean something is wrong with my fuel pump or ecu? Quote Link to comment Share on other sites More sharing options...
Shane Posted September 10, 2010 Share Posted September 10, 2010 ok my car was running and driving fine earlier today then i turned the car off to do some stuff and it started stalling when i started it....so i did the 12v thing and started it right up and it ran perfect...does this mean something is wrong with my fuel pump or ecu? Almost certainly the ECU I would say. Someone will verify this I am sure, but on a NA, i think the pump relay is fed from the main ecu and I would say that the next thing you need to do is beg steal or borrow a known good ECU to try. Cant recall if the NA has a seperate fuel pump ECU or not, dont think so. Ian C, Dude, CW would all know for sure. Sounds horribly like mine though. Loose batt connection leading to damaged ecu. Its not the fuel pump though, you have just proven that by hard wiring it. Quote Link to comment Share on other sites More sharing options...
