Ricky49 Precision Billet 6765SP Single Turbo Conversion Build
Ricky49
  • Replies 663
Posted Images
Ricky got a black carpet to go in and I had a couple of amps to fit so the interior was stripped.
The control box for the gauges was tucked down the side of the trans tunnel behind the carpet so I relocated it to the glove box.
In the top pic you can see on the centre panel by the gear stick, a previous owner had super glued something to the panel and it had left a nasty patch.
We repaired the panel, sanding the it down, painting and retexturing it to look like stock.image
Carpet removed
Amps wired in.
Black carpet fitted
Battery relocated to the boot, mounted in a custom battery tray.
Sub fitted, have Jamies box at the moment but may be making another one with an Alpine sub if Jamie wants it back. :)
Boot panel cut to fit battery and sub.
Interior refitted, wouldnt even no its all in there. :)
  • 3 weeks later...
And so it begins, before I even have driven the car as a single the next list of parts will soon be ordered.
I need to decide if its built engine or stroker.
For starters
ARP head stud kit
ARP crank stud kit
ACl bearings
TTC Idler Pulley
Unorthodox lightened pulley set
Unorthodox lightened crank pulley
New engine gasket set
Stock oil pump
Stock water pump
Billet Timing Tensioner belt bracket
Billet main caps
TRD engine mounts
TRD gear box mount
For starters
ARP head stud kit
ARP crank stud kit
ACl bearings
TTC Idler Pulley
Stock oil pump
Stock water pump
Billet main caps
TRD engine mounts
TRD gear box mount
looks exactly the same as my list but i have the parts now, just need the engine to be delivered. still need oil and water pump...
My advice would be leave it as it is and enjoy it for a while, at least that way it will give you time to get use to the power, 850bhp is a handful, mine trys to kill me at all opportunities.
Oh it will be a while until I have everything mate so plenty of time to enjoy it.
Been over to see Lee and the car today. I'm loving the way it's looking now, jamies old Advans look great against the silver body.
Also spoke with Lee about doing the twin fan set up so once I have all the Unorthadox lightened pulleys and billet tensioner bracket I will be going with that.
This quote is such a powerful inspirations to go single and push big power...! ILMAO
I seriously cannot wait to have a scary quick car...! ;-)
