SupraMan Mk4 Posted September 6, 2010 Share Posted September 6, 2010 Heya, I need to get pads and discs all round for my Jspec NA Aero. I was thinking of getting the UK Spec Discs (Larger) as opposed to the original Jspec ones that are currently on it. Does anybody know which dimensions I need to measure to ensure that they will fit, before I go ahead and purchase them? I have 18" alloys on them at the moment if thats any help. Also would I to order new calipers for the larger discs as well? Sorry Im a bit of a noob still when it comes to the Supra. Quote Link to comment Share on other sites More sharing options...
Geo Posted September 6, 2010 Share Posted September 6, 2010 You cant get UK disks and put them on a jspec car, unless you have UK Calipers. Its Jspec disks you will need Quote Link to comment Share on other sites More sharing options...
SupraMan Mk4 Posted September 6, 2010 Author Share Posted September 6, 2010 You cant get UK disks and put them on a jspec car, unless you have UK Calipers. Its Jspec disks you will need So as i wish to go UK Spec, providing they provide enough clearance from my current alloys, I *would* require UK Spec calipers also. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Geo Posted September 6, 2010 Share Posted September 6, 2010 So as i wish to go UK Spec, providing they provide enough clearance from my current alloys, I *would* require UK Spec calipers also. Thanks for the info. correct Quote Link to comment Share on other sites More sharing options...
Nic Posted September 6, 2010 Share Posted September 6, 2010 To convert front and rears you will need: Front Brakes 4 Pot front brake caliper x 2 323 x 30mm front brake disc x 2 Front brake pad set Shim kit x 1 Pad fitting kit x 1 Rear Brakes 2 Pot rear brake caliper x 2 324 x 16mm rear brake disc x 2 Rear brake pad set Pad fitting kit x 1 Quote Link to comment Share on other sites More sharing options...
SupraMan Mk4 Posted September 6, 2010 Author Share Posted September 6, 2010 To convert front and rears you will need: Front Brakes 4 Pot front brake caliper x 2 323 x 30mm front brake disc x 2 Front brake pad set Shim kit x 1 Pad fitting kit x 1 Rear Brakes 2 Pot rear brake caliper x 2 324 x 16mm rear brake disc x 2 Rear brake pad set Pad fitting kit x 1 Thanks Nic, Any idea of the clearance required? Would rather not fit any spacers if I had the choice. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted September 6, 2010 Share Posted September 6, 2010 From what I understand if you get j-spec brakes, good pads and braided hoses the only advantage of having the larger brakes is that they will perform better for longer periods of time due to better cooling. i.e. you can't really tell the difference between a good J-Spec setup and a UK setup unless on the track. Am I right? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted September 6, 2010 Share Posted September 6, 2010 Yeah a good j spec set up, pads, lines etc is quite handy Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 7, 2010 Share Posted September 7, 2010 Thanks Nic, Any idea of the clearance required? Would rather not fit any spacers if I had the choice. Here you go... I've just been through all this so I have all info. Let me know if you need more or PM me Quote Link to comment Share on other sites More sharing options...
