philsmith1a Posted September 4, 2010 Share Posted September 4, 2010 I have just fitted a double decat to my j spec tt, after fitting with a 52mm dia. RR it ran .9bar, I filed it out to 54mm and it is still .9bar. iv got a walbro pump but not yet fitted. The exhaust is a 3” blitz nur spec r. I doubt the boost isn’t rising due to the lack of a decent fuel pump, can anyone suggest what the issue could be? Quote Link to comment Share on other sites More sharing options...
clapyohandz Posted September 4, 2010 Share Posted September 4, 2010 Have you checked all your vaccum lines ? I can get to 1.5 bar with the RR on... Quote Link to comment Share on other sites More sharing options...
Lude Posted September 4, 2010 Share Posted September 4, 2010 i wish my boost would be that low. tbh mate, your better keeping it like that, then having a boost controller to increase the rest. i have the Blitz nur & double decat also, boost goes 1.4bar so its not you have a restrictive exhaust. either increase the Restricotr ring or get a EBC Quote Link to comment Share on other sites More sharing options...
clapyohandz Posted September 4, 2010 Share Posted September 4, 2010 Or just toss the RR ? Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 4, 2010 Author Share Posted September 4, 2010 I have checked the vacuum hoses simply by having a feel around while some one revs the engine. Is there a proper method for doing this? I would just get rid of the RR but i want to find a reason for it not affecting the boost Quote Link to comment Share on other sites More sharing options...
clapyohandz Posted September 4, 2010 Share Posted September 4, 2010 Right underneath the first turbo there are two very tiny thin lines. I wish I could post a pic but I do not have my car next to me. If one of them is not properly routed, it might be the reason. Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 4, 2010 Author Share Posted September 4, 2010 i think i found the ones you mean (about 10mm outside dia.)? everything looks fine with them. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 4, 2010 Share Posted September 4, 2010 I would do the following, remove the restrictor ring, do a test drive and see if it'll boost higher than 0.9bar - be careful with your right foot not to boost too high. If it will boost higher then the RR is adding too much of a restriction at the moment and needs the hole increasing further. Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 4, 2010 Author Share Posted September 4, 2010 cheers nick. will do. Quote Link to comment Share on other sites More sharing options...
Gambit Posted September 5, 2010 Share Posted September 5, 2010 I have the same thing. I get .9 with cat, RR or straight through. What smic do you have for the question? Would a crap smic make a difference or knackered waste gate? Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 11, 2010 Author Share Posted September 11, 2010 Right, first off I misread the boost gauge, it wasn’t .9bar it was 9psi! I’ve taken the rr out, took her for a run out and did a few high speed pulls and it did hit fuel cut once(at about 6500rpm)-boost gauge reading was 14psi. So I recon I must have a boost leak as the exhaust is 3” straight through or if there was a leak would the boost have stayed the same if it had a rr in or not?? Any ideas? Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted September 11, 2010 Share Posted September 11, 2010 I have a the same sort of thing , i have a double decat ,nur spec , fuel pump ,front mount , bov valve , boost controller , induction kit , fuel cut defender , The car was all done when i got the car and the boost controller was already set up , In 3rd and 4th gear hard pulls it makes spikes at 1.15 bar and holds 1.03 bar in 3rd and 1.05 bar in 4th in 5th and 6th im only holding just under 1 bar. the boost controller is on max . i know the car can make more as i have a pipe come off the boost controller one day and the car fit 1.8 bar , i let straight off as i know there was something wrong plus i had fuel cut , So why will the car not make and hold 1.2 bar , its been driving me mad for months . The car is a j spec tt 6 manual there is a rr ring fitted but im not sure what size , i have brought a 1.2 bar ring to put in a try . Rich. Quote Link to comment Share on other sites More sharing options...
James Posted September 11, 2010 Share Posted September 11, 2010 To the original poster - do you have a fuel cut defender? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 11, 2010 Share Posted September 11, 2010 So I recon I must have a boost leak as the exhaust is 3” straight through What exhaust model is it? Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 12, 2010 Author Share Posted September 12, 2010 I have a thor vfcc, not fitted at present as i wanted to make sure the boost gauge was reading correctly(i.e. fuel cut at 1bar). The exhaust is blitz nur spec r with 3" decats. Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 12, 2010 Author Share Posted September 12, 2010 Just to add, after a drive this morning i left the car ticking over for 5 min, the exhaust started blowing loads of white smoke. it has never done this before, if it is the turbo seals could this be causing the low boost pressure? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 13, 2010 Share Posted September 13, 2010 Sounds like one or both turbos are on the way out. This could be very costly I am afraid. I am finding the majority of used front turbos I get to send for re conditioning have bad cracks in the turbine housing wastegate seat. These can be welded but often crack again. I recommend new ones from Toyota for true peace of mind, but I am unsure if anywhere still has stock as they have discontinued them. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 13, 2010 Share Posted September 13, 2010 How much are new turbo's from Mr T? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 13, 2010 Share Posted September 13, 2010 They were over a grand each last time I checked. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted September 13, 2010 Share Posted September 13, 2010 They were over a grand each last time I checked. I thought I heard 1K each or around that:blink: Quote Link to comment Share on other sites More sharing options...
Nic Posted September 13, 2010 Share Posted September 13, 2010 but I am unsure if anywhere still has stock as they have discontinued them. I think it was the UK turbos that were in short supply, the J-spec turbos are definitely still available. Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 13, 2010 Author Share Posted September 13, 2010 Bad news! All I wanted was a reliable 400bhp. I’m thinking I might be better off buying some second hand turbos, I have found some on ebay with 3 months warranty ,I can’t justify going single as it’s an auto and I have been advised against hybrids. What to do?? Also should I stop driving it? If the seals went completely would I wreck the engine? Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted September 24, 2010 Author Share Posted September 24, 2010 I’ve sourced some very low mileage turbos, during fitting 3 cracked pipes were found so that was the boost leak sorted. In hindsight maybe I should have kept the old turbos as they only puffed the smoke the once and that was with no RR. I’m guessing most turbos with no back pressure in the exhaust would allow a drop of oil into the exhaust after a hard drive and long idle. Thanks for everyones help on this. Quote Link to comment Share on other sites More sharing options...
Gambit Posted September 25, 2010 Share Posted September 25, 2010 So now that you've changed your turbo's and replace the cracked pipes, hows your boost? Quote Link to comment Share on other sites More sharing options...
philsmith1a Posted October 13, 2010 Author Share Posted October 13, 2010 max boost is sorted. but now the 1st turbo wont spool up! Quote Link to comment Share on other sites More sharing options...
