w41k3r Posted September 2, 2010 Share Posted September 2, 2010 thought my bulb had gone tonight but turns out its some sort of faulty connection pulled the bulb out of the loom and inside it has melted the plastic a little now what do i do to fix it its the part the bulb plugs into do i just get another connector as surely it carnt be a new loom job? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 3, 2010 Share Posted September 3, 2010 The plug won't be listed on the general Toyota EPC, if you walk into a Toyota dealer they'll say they are not available separately. However the attached pdf file lists all the Toyota plugs and part numbers, you'll need to identify the correct one from the diagram. Alternatively I'd try to get hold of a 2nd hand one.toyota plugs.pdf Quote Link to comment Share on other sites More sharing options...
