colmcork Posted September 1, 2010 Share Posted September 1, 2010 Hi guys I know this subject has been discussed to death but I cant seem to find an answer to MY question:d. I am currently refurbing the j-spec brakes on my TT. Goodridge braided lines all round, fully flushed and using Toyota dot 5.1 fluid, Toyota refurb kit, have had all the discs machined ( even though there wasn't any signs of wear ) and must now sort out the pads. I have been in touch with Mr. Wilson and everything is hunky dory but my question, eventually, is this: As i will never be taking the soop anywhere near a track, and as it stands it is still limited to 112mph, am i really going to reap the benefit of Chris's very highly recommended fast road pads? Would i be just as well off using Genuine Toyota pads for all i will be asking of them? Sorry for long post:). And of course if you're reading this Chris I'd be delighted to hear your opinion:) Link to comment Share on other sites More sharing options...
pedrosixfour Posted September 1, 2010 Share Posted September 1, 2010 In a word, yes. If you enjoy driving your car and aren't afraid to flirt with the speed limits then fast road pads are a good idea. For starters the Supra is a heavy lump which means the brakes, especially the smaller set-up, are worked fairly hard at the best of times. It's not about braking from 200mph to a standstill. It's the ability of the pads to maintain their effectiveness over a period of time when using the brakes a bit harder than you would if you were just pottering down to the shops. Link to comment Share on other sites More sharing options...
add heywood Posted September 1, 2010 Share Posted September 1, 2010 I agree. always a good idea to try to improve on the efficiency of the brakes, especially j spec. Just think, a child may run in front of you, there may be a hazard in the road etc. Link to comment Share on other sites More sharing options...
Geo Posted September 1, 2010 Share Posted September 1, 2010 Fast roads pads tend to work from cold very very well, I have CW pads also on my UK setup and the difference is night and day. Highly recommended for road use. Link to comment Share on other sites More sharing options...
Kirk Posted September 1, 2010 Share Posted September 1, 2010 My fast road pads are nearly done for but there still working rather well Link to comment Share on other sites More sharing options...
Geo Posted September 1, 2010 Share Posted September 1, 2010 My fast road pads are nearly done for but there still working rather well you been giving them a good testing then Link to comment Share on other sites More sharing options...
colmcork Posted September 1, 2010 Author Share Posted September 1, 2010 Well thats it sorted then:). Thanks a lot for the input guys it is all very much appreciated. Will get ordering from chris tomorrow. Link to comment Share on other sites More sharing options...
Kirk Posted September 1, 2010 Share Posted September 1, 2010 you been giving them a good testing then Whatever gave you that idea? Link to comment Share on other sites More sharing options...
bodilx6 Posted September 2, 2010 Share Posted September 2, 2010 I completely disagree. I have and have had the CW pads for my car for well over a year now. They work fine and the main thing is to avoid pad fading. If you use your car like a normal road car and rarely go faster that the speed limits, the OEM pads will be fine. They will stop you from high speeds as well (I've been to the nürburgring with them several times and my brake fluid boiled before they did), but can be the weakest point if you trackday your car an have really good brake fluid but thats it. If you drive nice and easy and just do a pull once in a while, I would stick with the OEM pads. The reason for this is that the CW pads generate quite a lot more dust than the OEM pads which is a bit annoying if you don't reap the benefits from them. Link to comment Share on other sites More sharing options...
jackso11 Posted September 3, 2010 Share Posted September 3, 2010 do they wer out a lot quicker than standard OEM pads too? Link to comment Share on other sites More sharing options...
bodilx6 Posted September 3, 2010 Share Posted September 3, 2010 Dunno.. I wouldn't think so. At least not a lot. Used mine quite a bit for ½ a year+ and still had like 1 cm left. Link to comment Share on other sites More sharing options...
AndrewOW Posted September 3, 2010 Share Posted September 3, 2010 Has anyone have an idea of a rough cost of a set of OEM J-Spec pads? Link to comment Share on other sites More sharing options...
