AlanM Posted August 31, 2010 Share Posted August 31, 2010 (edited) Had the intermittant click and not starting so fitted a refurb kit from Mr T. Thought it had cured the problem but it is still the same - sometimes just a click, sometimes it starts no problem. Before buying another motor is there anything else that might be faulty? Would the relay cause the same symptoms? Edited August 31, 2010 by AlanM Request to shift (see edit history) Quote Link to comment Share on other sites More sharing options...
ilicos Posted August 31, 2010 Share Posted August 31, 2010 Same happened to me and it turned out to be that the cranking power on my battery was knackered. A new battery and all was sorted Quote Link to comment Share on other sites More sharing options...
AlanM Posted August 31, 2010 Author Share Posted August 31, 2010 (edited) I will try another battery on and see how that goes, thanks Edited August 31, 2010 by AlanM (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted August 31, 2010 Share Posted August 31, 2010 Sounds like battery to me. Quote Link to comment Share on other sites More sharing options...
bluecoup Posted August 31, 2010 Share Posted August 31, 2010 having this on the van at the mo mine is a bad battery connection Quote Link to comment Share on other sites More sharing options...
AlanM Posted September 4, 2010 Author Share Posted September 4, 2010 Well a new battery made no difference [sAD][/sAD] Think I will have to source another starter to try Quote Link to comment Share on other sites More sharing options...
nasoup Posted September 4, 2010 Share Posted September 4, 2010 The same thing happened to me, starter gave up completely so I fitted a refurb kit which worked fine for a about a week then it started playing up again so I got back under the car and managed to tighten the starter live nut about 1/8 of a turn since then it's given me no problems. Hopefully your fix will be this easy. Quote Link to comment Share on other sites More sharing options...
David Reid Posted September 4, 2010 Share Posted September 4, 2010 Did the starter refirb kit replace the solenoid, I think this could be the chase or your problem Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 5, 2010 Share Posted September 5, 2010 Make sure all connections are freshly cleaned with emery paper, use a quality terminal protector to keep out corrosion. I use Contralube 770 on every electrical connection. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 6, 2010 Share Posted September 6, 2010 Did the kit replace the starter solenoid copper contacts, or the brushes? It's the contacts that usually burn away and cause the trouble. Quote Link to comment Share on other sites More sharing options...
Purity14 Posted September 6, 2010 Share Posted September 6, 2010 Yes, as others have mentioned, replace the battery. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 6, 2010 Share Posted September 6, 2010 Yes, as others have mentioned, replace the battery. Quote Link to comment Share on other sites More sharing options...
