clifford 600 problem
potvolkoffie69
Pretty sure i had the same problem as you. The alarm has an internal battery which charges from the main battery now as you'v not had the car running for a while(guessing) the alarm battery is now low and won't start the car. Was the main battery hooked up to the car when you were charging it? If it was'nt then the alarm battery won't charge enough so I would suggest jumping it from another car.
