potvolkoffie69 Posted August 31, 2010 Share Posted August 31, 2010 I've read all the Clifford Problems , but didn't really came to this one... So I've just swapped my 2JZ GE to a new 2JZ GE, everything went without problems... Now we are to the exciting moment of starting the car... You can see the alarm works, by watching the blue bulb. We turn the alarm off... want to turn the engine on by turning the key, and then... immediately the alarm pops back on (blue bulb again) Anyone seen this problem or know how to fix it? Cheers Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 I seem to remember I've charged the battery fully, i saw something that this could cause trouble? Link to comment Share on other sites More sharing options...
jackso11 Posted August 31, 2010 Share Posted August 31, 2010 sounds like a flat battery to me. Does the alarm sound when you try to turn the key? Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 (edited) Just recharged the battery ... The alarm works perfectly, if you put it off, and inject the key, then it goes back on... Nothing happens not even the starter etc I really hope i can fix this , this is the last stage and i hope to be back online with my car soon And... the battery works fine ... Edited August 31, 2010 by potvolkoffie69 (see edit history) Link to comment Share on other sites More sharing options...
nasoup Posted August 31, 2010 Share Posted August 31, 2010 Even though your confident the battery is charged I would still put it down as the culprate. Even if all your dash lights ect are working that doesnt mean there is enough battery to start the car, if theres not enough battery life then the starter moter wont even attempt to turn over. So I would say jump the supra from another vehicle then if it still does'nt start then go from there. Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 (edited) Tried that , we're going to look if we didnt break a sensor for the fuelpump or starter... TOTAL update: The alarm works, but when we turn the key ... nothing happens... the alarm now works well , are there sensors for fuel pump etc? Edited August 31, 2010 by potvolkoffie69 (see edit history) Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 This tread can be closed, started a new updated one... Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 So after the clifford alarm ive got a new problem. Battery is charged, if i turn the key i can see the dashboardlights, but when i turn to start, nothing happens. To recall, i just switched the engine ... which sensors etc can be responsible? Sorry i cant give any more information Link to comment Share on other sites More sharing options...
Attero Posted August 31, 2010 Share Posted August 31, 2010 What's with all the threads? Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 Went very wrong i guess Link to comment Share on other sites More sharing options...
Geo Posted August 31, 2010 Share Posted August 31, 2010 what the hell have you started 3 threads all saying the same thing? Link to comment Share on other sites More sharing options...
Neil-NA Posted August 31, 2010 Share Posted August 31, 2010 Does it make a noise at all? starter motor or anything? Link to comment Share on other sites More sharing options...
Geo Posted August 31, 2010 Share Posted August 31, 2010 have you disingaged the Immobiliser? Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 Nothing , starter motor etc works, im working to delete the others , im sorry Alarm works as it should be so i guess it's a sensor geo ? Link to comment Share on other sites More sharing options...
ellis Posted August 31, 2010 Share Posted August 31, 2010 Are you going to post a new thread after each attempt to start it?? Link to comment Share on other sites More sharing options...
Neil-NA Posted August 31, 2010 Share Posted August 31, 2010 Can you give a wee bit more detail, you say you turn the key but nothing happens apart from the dash lights, how do you know the starter motor is working? is it clicking at all. If nothing happens as Geo said is there an immobiliser? Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 (edited) The dashlights light up, there is a warning sign... I've tested the starter motor before, works perfectly, battery works perfectly , and immobiliser... A clifford 600 , but seems to werk perfect too ...Looked over every engine part and connection and sensors etc Really going crazy here ... Edited August 31, 2010 by potvolkoffie69 (see edit history) Link to comment Share on other sites More sharing options...
Geo Posted August 31, 2010 Share Posted August 31, 2010 have you tried pressing the button to turn the immobiliser OFF, mine has it on the key fob Link to comment Share on other sites More sharing options...
potvolkoffie69 Posted August 31, 2010 Author Share Posted August 31, 2010 have you tried pressing the button to turn the immobiliser OFF, mine has it on the key fob Just got a key to turn the alarm off... the others have never worked... Link to comment Share on other sites More sharing options...
Dnk Posted August 31, 2010 Share Posted August 31, 2010 Does the engine actually turn over ? Link to comment Share on other sites More sharing options...
Harry Sachs Posted August 31, 2010 Share Posted August 31, 2010 Nevermind Link to comment Share on other sites More sharing options...
JustGav Posted August 31, 2010 Share Posted August 31, 2010 Threads merged and deleted. Link to comment Share on other sites More sharing options...
Harry Sachs Posted August 31, 2010 Share Posted August 31, 2010 When you turn the key what happens exactly? Do the lights fade? Link to comment Share on other sites More sharing options...
TopgunTT Posted August 31, 2010 Share Posted August 31, 2010 Have you tried bumping it and blown a fuse? Link to comment Share on other sites More sharing options...
Geo Posted August 31, 2010 Share Posted August 31, 2010 i think a video might help with the problem, so we can get a better look/listen what s going on? Link to comment Share on other sites More sharing options...
