clifford 600 problem
potvolkoffie69
I've read all the Clifford Problems , but didn't really came to this one...
So I've just swapped my 2JZ GE to a new 2JZ GE, everything went without problems...
Now we are to the exciting moment of starting the car... You can see the alarm works, by watching the blue bulb. We turn the alarm off... want to turn the engine on by turning the key, and then... immediately the alarm pops back on (blue bulb again)
Anyone seen this problem or know how to fix it?
Cheers
Just recharged the battery ... :)
The alarm works perfectly, if you put it off, and inject the key, then it goes back on... Nothing happens not even the starter etc :)
I really hope i can fix this , this is the last stage and i hope to be back online with my car soon :)
And... the battery works fine ...
Edited by potvolkoffie69 (see edit history)
Even though your confident the battery is charged I would still put it down as the culprate. Even if all your dash lights ect are working that doesnt mean there is enough battery to start the car, if theres not enough battery life then the starter moter wont even attempt to turn over. So I would say jump the supra from another vehicle then if it still does'nt start then go from there.
The dashlights light up, there is a warning sign... I've tested the starter motor before, works perfectly, battery works perfectly , and immobiliser... A clifford 600 , but seems to werk perfect too ...Looked over every engine part and connection and sensors etc :)
Really going crazy here ... :)
