Surrounds?
paddynewman
Im not sure where to put this...it may be technical depending on if I need to remove some clocks! tounge.gif
Basically I have an NA 1994 import, and some guy went into the side of me, got it repaired and got it sprayed red instead of silver for a change!
Now just to clean it up a little on the inside, i would like to take the clock surrounds off and get them done in the same red. Just keeps it looking neat I reckon.
Any idea if they just pull off or is it whole clocks out then unscrew stuff? Dont really want to break them or hack away at the dash!
Cheers in advance guys!
You can remove the trim from the binnacle by unscrewing and removing the top trim with the warning lights,etc., then the clock trim will simply pull off.
Just spraying this may look a little odd though..........................
I'll get a photo and photoshop it and decide that way before I tear it off... as i feel you may be right.. i'll check first!
