shaft Posted August 30, 2010 Share Posted August 30, 2010 can anyone tell me why my jspec tt has 2 different rev liminters?? one at arount 5250 and the normal one at 7250? hits the lower one when stationary mostly...? Link to comment Share on other sites More sharing options...
monsween Posted August 30, 2010 Share Posted August 30, 2010 2 step? Link to comment Share on other sites More sharing options...
shaft Posted August 30, 2010 Author Share Posted August 30, 2010 the ecu is standard bar an fcd? Link to comment Share on other sites More sharing options...
bodilx6 Posted August 30, 2010 Share Posted August 30, 2010 I have the same thing. Once in a while it hits a limiter @ roughly 5000. Car is BPU'ed by me, but 100% stock when I got it. It does have both SLD and FCD but these are very simple parts with no intelligence or additional features... Link to comment Share on other sites More sharing options...
shaft Posted August 30, 2010 Author Share Posted August 30, 2010 same here...hmm... Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 30, 2010 Share Posted August 30, 2010 most probly a safty thing not to over do the engine while stationary. Link to comment Share on other sites More sharing options...
shaft Posted August 30, 2010 Author Share Posted August 30, 2010 can anyone explain how to stop the low limiter no? Link to comment Share on other sites More sharing options...
Homer Posted August 30, 2010 Share Posted August 30, 2010 That is not normal, you all have a problem somewhere Are these cars auto's? On 2nd thoughts, why are you trying to go above 5000rpm when the car is stationary? Link to comment Share on other sites More sharing options...
CanisLupus Posted August 30, 2010 Share Posted August 30, 2010 On 2nd thoughts, why are you trying to go above 5000rpm when the car is stationary? Had that too but only when Stationary. Anything to do with it? Link to comment Share on other sites More sharing options...
shaft Posted August 30, 2010 Author Share Posted August 30, 2010 mines manual, i drive mine hard, when wheel spinning the limiter can come in early, let off for a second and then back on and it usually goes back up to normal... Link to comment Share on other sites More sharing options...
Homer Posted August 30, 2010 Share Posted August 30, 2010 Which FCD have you got and where is the dial set on it? It shouldn't do this, but have a few ideas for the cause. Link to comment Share on other sites More sharing options...
shaft Posted August 30, 2010 Author Share Posted August 30, 2010 greddy i think? cant remember the dial...i can check tomorrow. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 31, 2010 Share Posted August 31, 2010 Mine is 6 spd and I have never experienced it stationary. It happens once in a while going WOT in 1st, but ONLY in 1st. Also seen it once or twice while reving in neutral, coasting through a tunnel (usually on the way into the nürburgring ;-) ) Link to comment Share on other sites More sharing options...
