dandan Posted August 28, 2010 Share Posted August 28, 2010 Anyone recognise these wheels? Thanks Dan Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 28, 2010 Share Posted August 28, 2010 Nope, sorry mate, can't help with the wheel make/type. However, just so you know, 350z fitment offset wise is way off from the supra. 350z's have much much more aggressive offsets than the supra. So wheels that fit the arches nice like that on the Z, will never fit the supra (without over fenders.) Quote Link to comment Share on other sites More sharing options...
dandan Posted August 28, 2010 Author Share Posted August 28, 2010 Thanks for the advice - I had a feeling the Z offsets were very low so I am a bit wary. I've stumbled across these for sale and am just waiting on width and offset info from the guy selling them......thought I'd see if I could find out some more info while I was waiting Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 28, 2010 Share Posted August 28, 2010 It wouldn't surprise me if they were -15 -20. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 29, 2010 Author Share Posted August 29, 2010 It wouldn't surprise me if they were -15 -20. When you say -15 or -20.....would you say the Supra is -50 or +50? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted August 29, 2010 Share Posted August 29, 2010 Sorry, i meant + not - Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 29, 2010 Share Posted August 29, 2010 The std 350Z wheels are 18" and are 8" wide front and 8.5" rear with an offset of 30 and 33 respectively, so not vastly different, however on the std car they do tend to sit a bit recessed, so to achieve a good arch filled look, most fir 20mm spacers. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 30, 2010 Author Share Posted August 30, 2010 Sorry, i meant + not - The std 350Z wheels are 18" and are 8" wide front and 8.5" rear with an offset of 30 and 33 respectively, so not vastly different, however on the std car they do tend to sit a bit recessed, so to achieve a good arch filled look, most fir 20mm spacers. Apparently these are ET30. I'm not at all familiar with the 350Z so forgive the real dumb question. Is this 30mm offset in the same direction as our Supras or could this be 60mm different to an ET30 Supra wheel....ie is it possible that one is ET+30 and the other is ET-30 or are they not that different. Quote Link to comment Share on other sites More sharing options...
JamieP Posted August 30, 2010 Share Posted August 30, 2010 Apparently these are ET30. I'm not at all familiar with the 350Z so forgive the real dumb question. Is this 30mm offset in the same direction as our Supras or could this be 60mm different to an ET30 Supra wheel....ie is it possible that one is ET+30 and the other is ET-30 or are they not that different. Cant see it being -30. What widths are they mate Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2010 Share Posted August 30, 2010 No they will be +30 ET but like the Supra as you change wheel size and design, so the offsets change, a lot of std wheels like the 350Z tend to sit too far inboard, looks wise, so you can get away with considerable offset changes. Sorry i have never seen those wheels on a 350Z, might be worth popping over to the 350Z forum and ask, somebody may have seen then before. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 30, 2010 Author Share Posted August 30, 2010 Thank you for the posts and info fellas - much appreciated. I'm right to assume they must be 5x114.3mm PCD to fit a 350Z aren't I? I haven't seen them anywhere else yet either. They are 8.5" front and rear so no good for decent power but I'm looking for a set to run some proper winter tyres on for another Supe. I think a 235/40 up front and a 255/40 squeezed on the back should be alright and offer some improved cold weather grip over the 275 summer Toyos. Quote Link to comment Share on other sites More sharing options...
dandan Posted September 9, 2010 Author Share Posted September 9, 2010 These beauties just arrived and to my suprise the rears are 9.5" - not 8.5" Perhaps I won't be putting my winter tyres on them afterall Quote Link to comment Share on other sites More sharing options...
