Terminator Posted June 9, 2005 Share Posted June 9, 2005 Having a bit of a clear out to make way for more bits coming in. All parts from non VVTI JDM MKIV Twin Turbo Unless priced all parts to highest offers - PM please. Stock turbos removed at 27K miles. SOLD Apexi Variable exhaust control valve. £85 Stock Exhaust system from second cat. Only 20K Miles Excellent condition. NOW back on sale due to time waster. Stock paper air filter used less than 1K miles, just used when my Tom's panel filter was being washed. £10. First cat from turbo elbow removed from car at 21K miles, Offers. Stock plenum chamber/ in let manifold. Offers Throttle body with Trac removal kit fitted. ie only contains main butterfly. £80 HKS hard pipes (2) replaces plastic IC pipe work under the car from SMIC to TB elbow down pipe. £50 Polished HKS aluminium throttle body inlet elbow SOLD Stock turbo pipe work Offers Stock air box with lid , no broken clips. SOLD Standard Diff ( Auto 20K miles) Offers Leather three spoke non air bag S/W £40 Standard three spoke S/W/ £10 Apexi S-AFC. SOLD FSE. SOLD Ignitor pack SOLD Auto speedo dial cluster 180 MPH (No KPH) Offers Auto ECU SOLD --------------------------------------------- Advanced notification of parts to be available LATER this year/ start of new year Stock turbos to be removed at circa 42K miles £300 Stock turbo pipe work. Offers HKS aluminium inlet elbow with flange and HKS SQBOV£120 Chris Wilson - first decat pipe Offers Restrictor ring. Offers HKS second cat replacement pipe. Offers Stock air box with lid , no broken clips. £50 Toms Street Racing Panel filter. £30 After market up rated Auto ECU. £200 Trust SMIC No SALT damage Slight ding pressure tested 40psi. £250 More bits when I find them. Link to comment Share on other sites More sharing options...
Alex Posted June 9, 2005 Share Posted June 9, 2005 ......... Link to comment Share on other sites More sharing options...
stevie_b Posted June 9, 2005 Share Posted June 9, 2005 Would the stock air filter fit an NA? Link to comment Share on other sites More sharing options...
Terminator Posted June 9, 2005 Author Share Posted June 9, 2005 Would the stock air filter fit an NA?I know nothing of the N/A induction system. So can't help. I am sure other NA owners will know. Link to comment Share on other sites More sharing options...
Nic Posted June 9, 2005 Share Posted June 9, 2005 Would the stock air filter fit an NA? Yes the the NA and TT filters are the same. it is just the filter box that's different. Link to comment Share on other sites More sharing options...
stevie_b Posted June 9, 2005 Share Posted June 9, 2005 Thanks Nic Link to comment Share on other sites More sharing options...
colsoop Posted June 9, 2005 Share Posted June 9, 2005 Link to comment Share on other sites More sharing options...
adi2009 Posted June 9, 2005 Share Posted June 9, 2005 PM'd Link to comment Share on other sites More sharing options...
hadyn Posted June 9, 2005 Share Posted June 9, 2005 have you got any information on the 'aftermarket' auto ecu??? pm me how much you'd ideally want for it:) Link to comment Share on other sites More sharing options...
Terminator Posted June 10, 2005 Author Share Posted June 10, 2005 For enquiries please use PM's thank you. Link to comment Share on other sites More sharing options...
Terminator Posted June 11, 2005 Author Share Posted June 11, 2005 New part added Apexi VEGCV Link to comment Share on other sites More sharing options...
tDR Posted June 12, 2005 Share Posted June 12, 2005 New part added Apexi VEGCV What does the kit consist of and could I fit it to a different car? (Would be looking to fit it to my 1JZ mk3) Cheers, Brian. Link to comment Share on other sites More sharing options...
Terminator Posted June 19, 2005 Author Share Posted June 19, 2005 Can deliver smaller bits to Rockingham. Link to comment Share on other sites More sharing options...
Terminator Posted June 19, 2005 Author Share Posted June 19, 2005 What does the kit consist of and could I fit it to a different car? (Would be looking to fit it to my 1JZ mk3) Cheers, Brian. In cockpit infinately variable adjuster, cable link to valve that goes into a joint in the exhaust system. I was going to use it as a noise reduction device but change my mind. I'll post a pic. Link to comment Share on other sites More sharing options...
Terminator Posted June 19, 2005 Author Share Posted June 19, 2005 Apexi ECV Never used, all gaskets, bolts and fixings and Japaneese instructions. Fits any exhaust system with the same size exhaust flanges as the MKIV Link to comment Share on other sites More sharing options...
hadyn Posted August 13, 2005 Share Posted August 13, 2005 has the trust smic sold?first dibs if it hasnt Link to comment Share on other sites More sharing options...
ArghJae Posted August 14, 2005 Share Posted August 14, 2005 Does the HKS second decat pipe fit a UK spec? Link to comment Share on other sites More sharing options...
DAVEBOY Posted August 22, 2005 Share Posted August 22, 2005 How much for your decat front pipe and restricter.ring total cost +p p Link to comment Share on other sites More sharing options...
Terminator Posted September 6, 2005 Author Share Posted September 6, 2005 PMs please. List of parts updated. Link to comment Share on other sites More sharing options...
hadyn Posted September 6, 2005 Share Posted September 6, 2005 pm'd re the smic Link to comment Share on other sites More sharing options...
Terminator Posted October 13, 2005 Author Share Posted October 13, 2005 List updated at start of thread. Please contact by PM only. Offer,means just that, you make me an offer. Link to comment Share on other sites More sharing options...
hadyn Posted October 13, 2005 Share Posted October 13, 2005 so the smic is available now then? what condition are the fins in?are they flakey like many a stock smic? Link to comment Share on other sites More sharing options...
Dave Posted October 18, 2005 Share Posted October 18, 2005 is the first decat pipe for an n/a or a turbo??? Link to comment Share on other sites More sharing options...
