My Supra got mapped!
Tenttu
Woohoo!! Finally, after a year of waiting to get my car running again i got it back on the roads! The car is -94 TT 6 speed JDM Ummm... my spec list is quite modest but:
Stock engine
Holset hx 50 mfs
Sard 800cc
Bosch 044
Fuel dampner bypass line
Greddy 3-row cooler
3,5" exhaust
HKS F-Con V Pro Gold
Tial 60mm wastegate
Exedy carbon-carbon clutch
and last but not atleast 1,16bar of boost!
To be honest my mapper didnt have the time to raise boost more and i will have to just live with what i got :tongue:
600,6 hp and 760nm or 560 ft/lb of torque @ 1,16bar :)
I have to say that i am VERY satisfaid after all the waiting!!
Edited by Tenttu (see edit history)
The torque btw is 560 ft lbs, as Wez says very good results at such low boost, what are the turbo specs??? Most singles are way form their efficiency range at that boost.
Holset HX50 MFS
MFS Compressor 67/98mm
Turbine 72/86mm
Exh 19cm2
T4 / HX50
Max rpm 115,000
Max gain 0,62kg/sec (83 lbs/min )
Max pressure 4,6
Shame on them picking on that little 600;) Different story if they had a 1000 next to them. Still a quick car though:d
Yeah!! I hate when people do that :D That R6 had timed 11.3sek and 121mph on the quarter-mile :blink: Still, that supra needs more power, me thinks :innocent:
My run at Speedparty in Lappeenranta Airfield 4.9.2010
Not a total clean run because there was raining quit a bit and i was all over the place untill i hit 4.gear.. But still acceptable speed at 289km/h wich is 179mph. In dry track i would run over 186mph i reckon but untill that happens 179 is my personal record :) Ou this is 0 to 1700 metres so its a looong mile :p
Yeah but they are slow from a roll on, I had another play with a diff single turbo supra last night, not even close;)
  • 8 months later...
Last friday i made it to the 700 -club! 708hp and 610ft/lb. This was on totally stock jdm engine (exept injectors and fuel pump) stock fuel lines etc and at 1.44bar! I will post dyno plot when can.
