Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 always wanted to do a burn out without moving forwards - like to big boys do at drag strips. Is it as simple as reving the nuts off your car, slip the clutch and quickly sticking your left foot on the brake peddle ? OR using your right foot to rev AND brake at the same time ? OR do they have a special switch device on the dash which applys the front brakes ? This is not the kind of thing i can practice outside my house and i don't want to look a twat at Santa Pod so if it too difficult i'll opt for the traditional method (option 1 but without applying the brakes) Quote Link to comment Share on other sites More sharing options...
The Hornet Posted June 9, 2005 Share Posted June 9, 2005 Buy an auto hehe Quote Link to comment Share on other sites More sharing options...
tobyg Posted June 9, 2005 Share Posted June 9, 2005 Option 2. Hold it the revs high and drop the clutch in. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Author Share Posted June 9, 2005 Option 2. Hold it the revs high and drop the clutch in. i take it you shouldn't apply the brake too much just enough to stop it rolling forward, as the backs would start glowing sounds tricky is it ? best i wait for it to rain and find a big dis-used car park Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Author Share Posted June 9, 2005 Buy an auto hehe i remember seeing an auto supra do a false start at Santa Pods as he was keeping the revs high with his foot on the brake but pushed the car (front wheels not turning i.e. locked up) over the start line before the lights went green. - i'd thought he'd started wheelspinning before the front wheels started sliding ? Quote Link to comment Share on other sites More sharing options...
cashpoint Posted June 9, 2005 Share Posted June 9, 2005 Line lock! Quote Link to comment Share on other sites More sharing options...
Marco Posted June 9, 2005 Share Posted June 9, 2005 Get a line lock kit (or how is it called?) to disable your rear brakes. (edit-> beaten to it by cashpoint hehe ...) Quote Link to comment Share on other sites More sharing options...
tobyg Posted June 9, 2005 Share Posted June 9, 2005 I had a go in a quite area after going drag racing, and didn't find it too hard, just press the brake hard enough so you don't move forward. Quote Link to comment Share on other sites More sharing options...
The Hornet Posted June 9, 2005 Share Posted June 9, 2005 have left foot braked in mine in the dry, it didnt move forward unless i wanted it to. But would do it for long as: Tyres, plus have no line lock so rear brakes etc. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Author Share Posted June 9, 2005 Line lock! how do they work, is there a switch on the dash that disconnects the back brakes ? Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Author Share Posted June 9, 2005 have left foot braked in mine in the dry, it didnt move forward unless i wanted it to. But would do it for long as: Tyres, plus have no line lock so rear brakes etc. so basically if you don't have "line Lock" then stick either foot on the brake pedel. - under normal driving doesn't it feel all weird and really sensitive when you use your left foot to brake - you've all tried it once i'm sure ! Quote Link to comment Share on other sites More sharing options...
The Hornet Posted June 9, 2005 Share Posted June 9, 2005 Depends on how much you do it it doesn't take long to get used to it .... Quote Link to comment Share on other sites More sharing options...
MONKEYmark Posted June 9, 2005 Share Posted June 9, 2005 easy on auto foot on front brake in 1st gear build revs tyres will start spinning with line lock you press front brake press and hold in line lock button take foot off front brake should hold it on spot on button. when you realease button car moves forward. i have broken beam at santapod, was giving it plenty of revs on line holding on footbrake, there was that much grip on rear drag tyres it pushed car through beam causing a false start. you would not get that on street tyres as the rear wheels will just start spinning on spot. practice Quote Link to comment Share on other sites More sharing options...
Guest L80OUS Posted June 9, 2005 Share Posted June 9, 2005 Or maybe you should buy a Nova or Escort front wheel drive to make it easyier for yourself, doing this with also put you in the right category Quote Link to comment Share on other sites More sharing options...
attilauk Posted June 9, 2005 Share Posted June 9, 2005 Or maybe you should buy a Nova or Escort front wheel drive to make it easyier for yourself, doing this with also put you in the right category how does owning a nova make you a drag racer? Quote Link to comment Share on other sites More sharing options...
The Hornet Posted June 9, 2005 Share Posted June 9, 2005 Drag queen maybe Quote Link to comment Share on other sites More sharing options...
Jake Posted June 9, 2005 Share Posted June 9, 2005 i take it you shouldn't apply the brake too much just enough to stop it rolling forward, as the backs would start glowing sounds tricky is it ? You can apply the brakes quite hard if necessary. The brakes don't start glowing when you brake on the motorway at 90mph do they? It's fine. Doesn't do your clutch any favours though. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Author Share Posted June 9, 2005 Or maybe you should buy a Nova or Escort front wheel drive to make it easyier for yourself, doing this with also put you in the right category I was referring to warming tyres up before a drag race as appose to ASDA car parks etc Quote Link to comment Share on other sites More sharing options...
Guest L80OUS Posted June 9, 2005 Share Posted June 9, 2005 how does owning a nova make you a drag racer? This thread isnt about drag racing, its about doing a burn out such as people on drag strip, he used that to decribe what he ment! Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted June 9, 2005 Share Posted June 9, 2005 Line lock is the PROPER way to do it! All the other ways mean you burn out other parts of the car, clutch and rear brakes... http://www.horsepowerfreaks.com/sale/performance/Brakes/Line_Lock_Kits Quote Link to comment Share on other sites More sharing options...
