Greddy Gauges - any nerds here?
Lude
right guys, i have a Greddy oil pressure Warning gauge.
not just the normal electrical one, the one with the green & red warning lights, like this
http://www.hpautoworks.com/images/62mm.jpg
this connects to a grey box like this by the orange/brown connector/block
then there is a wire which goes from the grey box to the sendor (via the yellow connector/block)
http://i1.frsimg.com/images/detailed_images/Greddy_16401406_1.jpg
this is the sendor
now ive lost the wire (third pic)
you can get replacements, but some sites sugest there are 2 versions, one for the standard elec gauge, and one for warning gauge?
this true? anyone know?
found this one
http://www.wbperformance.com/store-products-16401703-Greddy-Informeter-Touch-Pressure-Sensor-Harness-Boost-Oil-Fuel_1095746804.html
the end has a white connection block on tho, not yellow. i think ive seen some yellow ones too?
its just 3 pin connector as far as i can tell, so should work ye?
Edited by Lude (see edit history)
  • 4 weeks later...
  • 1 month later...
it is seperate, found it here,
http://cgi.ebay.com/ebaymotors/GREDDY-PRESSURE-SENSOR-HARNESS-BOOST-OIL-FUEL-16401703-_W0QQcmdZViewItemQQhashZitem27b6118ad4QQitemZ170558327508QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
but it sounds like there are 2 versions of it?
but i cant see how it coudnt work as its just a wire with 3 pins/conections in
Part you need is 16401608 GReddy SMI Oil Pressure Harness 2.5m.
Am I officially a Nerd now :(
thanks mate! :)
so whats the difference between part 16401703 as on this
thanks nic. upon checkin the greddy site on this page
http://www.greddy.com/products/electronics/gauge-accessories/
i beleive i need
part 16401406 - pressure sensor harness - warning
they also do
part 16400064 - pressure sensor harness - electric (for the standard non warning version)
there is a price difference between the 2, they all seem to have 3 wires but just the connectors are different, probably just a way of making more money i guess.
i found it on ebay here, and the end of it is yellow, as per the unit it goes to.
i think we are both very very nerdy, thanks for your help ! :)
