SupraAyf Posted August 26, 2010 Share Posted August 26, 2010 Guys, This is a long shot but I know we have a couple of very knowledgeable ‘350Z’ guys on the forum. I have a set of Rays Gram Lights 57F Pros in the garage which I am thinking about fitting to a 350Z GT (the one with the Brembo brakes). The Rays fit over UK Supra Brakes with 2-3mm to spare; the offset being circa +35mm and both cars use a PCD of 114.3 Do any of you fine fellows know if my wheels would fit the 350 GT? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 26, 2010 Share Posted August 26, 2010 You will need spacers to clear the Brembos, ideal offset for 350Z kind of depends on size and spoke design, the std 18" are 8" wide front and 8.5" rear with an offset of 30 and 33 respectively, 35 offset will tend to sit too far inboard on the 350Z, will look a lot better with 20-25 spacers to fill the arches, as even the std wheels look too far in and don't fill the arches. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted August 27, 2010 Author Share Posted August 27, 2010 You will need spacers to clear the Brembos, ideal offset for 350Z kind of depends on size and spoke design, the std 18" are 8" wide front and 8.5" rear with an offset of 30 and 33 respectively, 35 offset will tend to sit too far inboard on the 350Z, will look a lot better with 20-25 spacers to fill the arches, as even the std wheels look too far in and don't fill the arches. Thanks mate, much appreciated - sounds like tip-top advice to me;) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 27, 2010 Share Posted August 27, 2010 Thanks mate, much appreciated - sounds like tip-top advice to me;) No problem:) looking at the design of those wheels, you may actually get away with clearing the Brembos, but they will still look to recessed without spacers, i run 22 offset with 19" wheels on my skyline 350GT (same chassis etc as 350Z) and thats just about right, any more and the rear arches would need serious rolling. Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted August 27, 2010 Author Share Posted August 27, 2010 No problem:) looking at the design of those wheels, you may actually get away with clearing the Brembos, but they will still look to recessed without spacers, i run 22 offset with 19" wheels on my skyline 350GT (same chassis etc as 350Z) and thats just about right, any more and the rear arches would need serious rolling. You're a star - thanks good mate;) Quote Link to comment Share on other sites More sharing options...
