Got spark and fuel, but no combustion @ cyl#3?
Guest Roel
I've got this strange (?) problem.. :( Really would appreciate some help here..
What I've checked:
- Coils all get 12v (IGN ON)
- Injectors all get about 9v (IGN ON)
- Did the spark test
- Compression was OK
- Changed coils
- Changed spark plugs
I know the injector is working because the sparkplug is soaked. When I then fit my old sparkplug, this one also gets soaked... Lots of fuel out of the exhaust too....
Btw I know I'm not getting a combustion on cyl #3, because the manifold runner stays cold.
Could this be a faulty injector? Or is the spark too weak?
TIA! :)
Tried some things today.. Problem is still there.. :(
Things we've tried;
- changed all the coilpacks
- changed the complete fuel rail with other injectors
- checked compression on all cylinders (OK)
- checked the loom at the ecu side, looks good.
- double checked for spark at cyl #3
@ Nodalmighty: I 'm thinking the same thing, within seconds gasoline is pouring out at the exhaust if we connect the connector of the injector #3
I think the ecu is defective or maybe the loom somewhere?
Thanks for the help guys! Yesterday I tried to help Roel on this problem, I brought coilpacks, injectors and a igniter. We know for sure now that injector 3 stays open when we start the engine. The red/green wire from injector 3's connecter to the ECU is ok.
The injectors are controlled/switched via ground indeed, but how can I check if the ground-wire on that injector is short circuiting or faulty? The J-spec ECU pinout doens't show a "injector ground" pin, and I can't find a J-spec wiring diagram for the injector ground. Where does the ground wire from the injector 3go to, can anyone help us?
The injector has one wire that connects to a 12V source (that's live when the ignition is on - could be black/orange or red) and a switched ground wire (the red/green one). You need to see if the red/green wire is connected to ground when it shouldn't be i.e. when the ECU is commanding the injector closed.
You need to start by disconnecting injector #3 and the ECU. Use a multimeter set to either the continuity or resistance range. Check to see if there is an electrical path between the red/green wire and the chassis (the - terminal on the battery will be fine). If the resistance is high (e.g. more than 1000 Ohms) your harness will be fine and the ECU is suspect.
There isn't a specific "injector ground" pin, each injector has its own pin on the ECU and the ECU internally switches these to a ground when it wants them to open. Injector number 3 is controlled by pin B18 on the ECU, but I doubt this is at fault. more likely is the wire going from the injector to the ECU is damaged and shorting out to the car body, causing a permanent earth switch.
Take the plug off the injector and check for continuity between pin 1 on the injector plug and the battery negative. There should be infinite resistance until the injector fires - if there is low or no resistance, you've got a short on that wire somewhere and that's causing your problem :)
Okay guys.. I've tried a couple of things yesterday.. But I'm kind of stuck at the moment... :blink:
I've first cut the wire at the ecu (red/green b18) and at the injector #3 (also red/green). Then soldered a fresh new wire between the two.
No result..
My friend Digital sent me his spare ecu, and I tried this one yesterday. Engine is still running on 5 cylinders. And at cyl3 is still no combustion (runner stays cold).
Here the strange part of the story:
So I removed the spark plugs. There was NO fuel on the spark plug #3. I also noticed that the fuel isn't pouring out of the exhaust while the engine is running with this ecu. Plugging in and out the connector of injector 3 while the engine is running makes no difference.
In other words.. I think the injector isn't opening at all now! :blink:
Then Soldered the original red/green wire at the injector and ecu connector again. No result..
Decided to try my own ecu again, and the injector #3 was stuck open and fuel pouring out of the exhaust again.
What to do next... Think I'm getting crazy haha.... Must have done something wrong I guess.. :confused:
Somehow (without changing anything!) cylinder 3 works like it should do!
But.. The problem has moved. Now the runner of cylinder 6 stays cold :blink:
When I unplug/plug the connector of cyl 6 while it's running, the engine doesn't sound/run different.
Strange eh...???
Try checking the crank position sensor and the two cam position sensors. There's a manual on here somewhere with the expected resistance values. If you have access to an oscilloscope, try looking at each of the three waveforms with the engine running. You may have a weak signal from one of the sensors.
It might be a pain to do but it's worth a try. :)
