johnd-mkiv Posted August 25, 2010 Share Posted August 25, 2010 when converting your autos to manual, what do you do about the ecu not thinking its an auto any more ?? im having trouble with my 1jz spluttering around 4 and read several problems to the ecu thinking its still in park or neutral john Link to comment Share on other sites More sharing options...
ray007 Posted August 25, 2010 Share Posted August 25, 2010 pm ryan g, he did the wiring on mine, or pm littlenum, he also done the conversion Link to comment Share on other sites More sharing options...
Homer Posted August 25, 2010 Share Posted August 25, 2010 You'll need to do the wiring mod on the gearbox plug (can't recall what it needs now, but there are some threads on the forum discussing it) I don't beleive there are any other changes needed to the wiring and the stock auto ECU should work fine with the manual. I recall something about it retarding timing very near the rev limit but that shouldn't cause an issue in mid range. Dude or Keron will know I am sure.. Link to comment Share on other sites More sharing options...
JustGav Posted August 25, 2010 Share Posted August 25, 2010 Two sets of wire if I'm right, I can look up the colour code if need be. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted August 25, 2010 Share Posted August 25, 2010 Not really much help to this thread but how much would something like this cost roughly ? Link to comment Share on other sites More sharing options...
Swampy442 Posted August 25, 2010 Share Posted August 25, 2010 Spluttering around 4 whats? If its 4k revs its not the start switch as its already started lol Link to comment Share on other sites More sharing options...
ray007 Posted August 25, 2010 Share Posted August 25, 2010 Not really much help to this thread but how much would something like this cost roughly ? depends on what gearbox your going for? Link to comment Share on other sites More sharing options...
Fitz Posted August 25, 2010 Share Posted August 25, 2010 Spluttering around 4 whats? If its 4k revs its not the start switch as its already started lol Could be him trying to start around 4 o'clock in that case I'd wait til 5, or go early and start it at 3 Happy to Help Link to comment Share on other sites More sharing options...
johnd-mkiv Posted August 26, 2010 Author Share Posted August 26, 2010 lol from what I have read it needs the neutral start switch connected so the ecu knows the cars cranking but it will run disconnected as mine does, on the 1jz the sta wire and nsw as seen on the ecu pin out below need to be connected or the car splutters like mine. http://www.clickdesign.co.uk/supradupra/html/1jz_wiring.html This post describes the problems im having, the STA wire up in here is simple enough but the NSW wire im unsure of wiring as my engine loom runs to a kit car style loom with no NSW wire to pick up from. http://www.toymods.org.au/forums/showthread.php?p=870699#post870699 heres a wire diagram of the nsw http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=038 Looks to me like both wires splice into the ignition trigger wire, I have tried this but the car brings up the water temp sensor code for the ECU Im now thinking once the car had cranked an runs these wires will now be running to earth, but shouldnt as the above post describes running to a relay. Im no electrician but if some one can help me theres a few beers in it im sooooooooooo close to finnishing this car now and believe this to be the problem. I have changed coil packs plugs ignitor coil pack clips checked and terminals tightened for a better conection crank angle sensor water temp sensor set up tps from a toyota manual checked, cam pos sensors and map sensors with a meter all in tolerance The aeromotive FPR ignition on is showing just under 4 bar when running around 3 1/2 bar Profec B boost controller is showing 1.2 bar of boost with 10% gain blanked the BOV off just in case that was letting by still same. Link to comment Share on other sites More sharing options...
dude Posted August 27, 2010 Share Posted August 27, 2010 The neutrals start switch is purely that a start switch, without that the thing will not turn over, on a us car it would go to the clutch pedal. Link to comment Share on other sites More sharing options...
Ryan.G Posted August 27, 2010 Share Posted August 27, 2010 None of those links above work mate but from looking at the diagrams i have you need to link the NSW wire from the ecu to the ST1 output on your ignition barrel. Then the STA input on the ecu needs to go through the the Neutral switch but to bypass it at the moment just give 12v to the STA pin on the ecu. I would have said they go the other way around but from looking at the wiring diagrams it seems the above is correct. Ryan Link to comment Share on other sites More sharing options...
