steve spedd Posted August 25, 2010 Share Posted August 25, 2010 I have some Siemens DEKA IV ( DEKA 4 ) Mototron 60lb/hour High Impedance Injectors. This is the spec: * Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required) * Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min * Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min * Gain: 0.11ms/mg * Offset: 0.055ms * Turn on time @ 14VDC: 1.14ms * Turn off time: 0.85ms @ 600KPa * Connector: Bosch EV1 * Series: DEKA 4 ( DEKA IV ) * Orifice Type: Multi-orifice * Spray Pattern: 30 Degree Spray Cone Any ideas where i can get the o-rings that fit from the bottom of the injectors to the engine? Many thanks, Steve Link to comment Share on other sites More sharing options...
steve spedd Posted August 25, 2010 Author Share Posted August 25, 2010 Forgot to mention that these are for the stock NA fuel rail. Thanks Link to comment Share on other sites More sharing options...
Geo Posted August 25, 2010 Share Posted August 25, 2010 whifbitz, im sure darren fitted some to mine when installing my injectors, this was on my TT though Link to comment Share on other sites More sharing options...
steve spedd Posted August 25, 2010 Author Share Posted August 25, 2010 Thanks George. I will pm paul Link to comment Share on other sites More sharing options...
steve spedd Posted August 25, 2010 Author Share Posted August 25, 2010 oh n i got my BW turbo, its coming together now Link to comment Share on other sites More sharing options...
kieren1234 Posted December 28, 2010 Share Posted December 28, 2010 Bump for steve. We realised he needs new o rings today as one is missing. Any ideas again? Thanks. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 31, 2010 Share Posted December 31, 2010 fiveo motorsports in the US. Bruce will know just what you need and ships straight away. http://www.fiveomotorsport.com Link to comment Share on other sites More sharing options...
