bigsupra Posted August 25, 2010 Share Posted August 25, 2010 So I made a trip to the store today, I just got some 80 sand paper and 400 sand paper, the 80 is just to smoothen it out after. I also got goof off 2 and some WD40, good off 2 seemed to work better. So basically I am trying to remove the sticky (rubber coating) layer from the supra dashboard so it's all smooth and ready to paint. Jesus christ it's a big pain in the ass, I was working on one small piece for about 1 hour, and all the black stuff sticks on the sand paper so it just makes it even harder. I didn't even finish it becuase I had enough of it. What should I use to scrub that son of a bitch off? I was thinking about steel wool? I just need something tough, once the sticky crap is off it should be straight forward from there. THANKS Quote Link to comment Share on other sites More sharing options...
edge Posted August 25, 2010 Share Posted August 25, 2010 When I done mine i soaked each panel in the sink in fairly warm water and soap then used one of them green Brillo pad things to get the black stuff off. It's not a nice job but it took me about 2 hours to do the lot Quote Link to comment Share on other sites More sharing options...
adnanshah247 Posted August 25, 2010 Share Posted August 25, 2010 hey mate heres a guide i made to help you do your dash:- http://www.mkivsupra.net/vbb/showthread.php?t=195184&highlight=guide+painting+dash if you scroll past jamies dash piece theres a guide to me doing a complete dash. Quote Link to comment Share on other sites More sharing options...
bigsupra Posted August 25, 2010 Author Share Posted August 25, 2010 thanks for the link adnanshah247, I think my only problem is removing the rubby stuff from the dashboard. I just need to pick some sand papers that more rough. btw, how did you remove the lighter thing from the center dashboard, also from the right side where the key is, how did you remove that button (beside the AC). I can't seem to remove those things. Quote Link to comment Share on other sites More sharing options...
evinX Posted August 25, 2010 Share Posted August 25, 2010 Dont sand it, do dont use 80, thats well coarse youll scratch the plastic underneath, get some electrical board alcohol cleaning solution from maplins, turn the rubber to water after a few soaks and scrubs, then 800 the dash and prime as its plastic, scrape the plastic and your looking at skimming it with filler or etch primer...etch primer, EIWWW. Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted August 25, 2010 Share Posted August 25, 2010 I did the same as edge, hot water, fairy washing up liquid and a few of my misses Brillo pads, it worked a treat Quote Link to comment Share on other sites More sharing options...
evinX Posted August 25, 2010 Share Posted August 25, 2010 lighter has to twist round and push through from the rear, centre will come out then the black surrounding will push out Quote Link to comment Share on other sites More sharing options...
Stonkin Posted August 25, 2010 Share Posted August 25, 2010 Mine was carbon wrapped and not painted but i used those red brillo pads dipped in clit bang, wasnt easy but came off with a bit of effort and it also keys the surface as prep. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted August 25, 2010 Share Posted August 25, 2010 thanks for the link adnanshah247, I think my only problem is removing the rubby stuff from the dashboard. I just need to pick some sand papers that more rough. btw, how did you remove the lighter thing from the center dashboard, also from the right side where the key is, how did you remove that button (beside the AC). I can't seem to remove those things. Do you man the button to control how bright the cluster lights are? If so you will need to carefully price the round button off, then there is a nut which you can remove underneath it. The lighter you will see has some notches that make it click into place. Again a bit fiddly but you need to lift the notches up, you may need to place something small like a cocktail stick under a couple of them, while you free the rest then i does come apart. Quote Link to comment Share on other sites More sharing options...
bigsupra Posted August 25, 2010 Author Share Posted August 25, 2010 (edited) I already bought the paint (plastic primer) which is white, and matte black for the finish. I only got 1 can of the matte black paint, should that be enough ? I already started on one piece of the dash, and like I said the rubbery stuff was a pain to remove... I will try to remove it with hot water in the sink, I just need to remove those two things I mentioned. Edited August 25, 2010 by bigsupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Stonkin Posted August 25, 2010 Share Posted August 25, 2010 I doubt it mate, not after 2 or 3 layers Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted August 25, 2010 Share Posted August 25, 2010 I used nail polish remover when I did mine, not a pleasant job but did take the coating off pretty easily. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted August 25, 2010 Share Posted August 25, 2010 i used grafiti remover spray i found in halfords. did the job well. sprayed it on. then i scraped it off with a small scraper thing i had. gave me the odd scratch in the pastic but that was easily resolved with sand paper. Quote Link to comment Share on other sites More sharing options...
RiceRocket Posted August 25, 2010 Share Posted August 25, 2010 PAINT IN THE ASS /help Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 25, 2010 Share Posted August 25, 2010 Even worse is thought of nail varnish remover to get it out.... There are some right weirdos on here these days Quote Link to comment Share on other sites More sharing options...
Supranature Posted August 25, 2010 Share Posted August 25, 2010 I know its done, but Isopropyl alcohol from your local Chemist makes it easy. One can is nowhere near enough. I have just done a spare dash I have acquired, and needed 2 black finish cans. You need to apply several layers to get it "properly" black, then lacquer it, again a few coats, to protect it. I still need to do the right side key panel and the one on the door card, so that makes 3 I will have used. Quote Link to comment Share on other sites More sharing options...
evinX Posted August 25, 2010 Share Posted August 25, 2010 Dont sand it, do dont have to laugh @myself for this one:D Quote Link to comment Share on other sites More sharing options...
Ewen Posted August 25, 2010 Share Posted August 25, 2010 How did you get paint in your ass whilst prepping a dashboard ? Quote Link to comment Share on other sites More sharing options...
bigsupra Posted August 26, 2010 Author Share Posted August 26, 2010 (edited) I meant pain in the ass*, lol. I used nail polish remover and that stuff worked great with some effort. I finishd painting my bashboard, started with white primer, and now it's matte black and the paint already dried some what, I'll wait a few more hours to see if it will get any better. I just ran my finger nail along the edge and the paint seems to scrape. What kind of paint should I get to "protect" the matte black paint ? Edited August 26, 2010 by bigsupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Supranature Posted August 26, 2010 Share Posted August 26, 2010 See post 16-lacquer, satin or matt, NOT gloss............... Quote Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted August 26, 2010 Share Posted August 26, 2010 Thinners and a rag. then use plastic primer before actually priming them. not a nice job. Quote Link to comment Share on other sites More sharing options...
