Geo Posted August 24, 2010 Share Posted August 24, 2010 (edited) Right, Just had the car out for a little spirited drive, as she's been sat for 5 days now. Im getting a knocking noise coming from the brakes when driving, more like a clunk. Now here is the thing when i engage the brakes the noise goes away, soon as i release its back. iv had this a while now, just never got round to posting it. UK Calipers CW Fast Road Pads New Shims Fitted New brake Fluid Im thinking that the Pads might be slightly smaller and are ratting around in the caliper, only thing i can think off. Idea's guys?? If need be im off friday so i'll whip them off for a check Edited October 9, 2012 by Geo (see edit history) Link to comment Share on other sites More sharing options...
madwoody1 Posted August 24, 2010 Share Posted August 24, 2010 your wheels are tight? no i'm not joking Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 your wheels are tight? no i'm not joking Yup, defo. But i'll double check again Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2010 Share Posted August 24, 2010 Are the anti knock clips installed? If not they may knock until some brake dust builds up, especially if the calipers are a bit worn where the pads sit. The anti knock clips are the ones that fit over the caliper pins and the little corner ones. Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 Are the anti knock clips installed? If not they may knock until some brake dust builds up, especially if the calipers are a bit worn where the pads sit. The anti knock clips are the ones that fit over the caliper pins and the little corner ones. that i dont know bud, you got a pic of them and i can check? if not can i buy them from toyota? Link to comment Share on other sites More sharing options...
Rich8v Posted August 24, 2010 Share Posted August 24, 2010 Watching this thread with interest, because I have the same problem. On first inspection i found that one of the caliper bolts wasn't done up correctly due to a damaged thread. This allowed the caliper to move. But after sorting that out it still knocks. I have CW pads and new discs sat in my room as there due a change. When changing my brakes i plan on checking all my suspension bolts are torqued up, including my subframe. But if that dosn't solve it i will be stumped. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2010 Share Posted August 24, 2010 These shims and clips Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 Watching this thread with interest, because I have the same problem. On first inspection i found that one of the caliper bolts wasn't done up correctly due to a damaged thread. This allowed the caliper to move. But after sorting that out it still knocks. I have CW pads and new discs sat in my room as there due a change. When changing my brakes i plan on checking all my suspension bolts are torqued up, including my subframe. But if that dosn't solve it i will be stumped. does it go away when the brakes are engaged dude?? must be something simple Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 These shims and clips cheers Chris i'll check tomorrow ta Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2010 Share Posted August 24, 2010 Personally I don't fit any of them unless the customer is after totally silent brakes, they can promote pad sticking and the big shims on the nbacks of the pads add sponginess to the pedal feel. Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 Personally I don't fit any of them unless the customer is after totally silent brakes, they can promote pad sticking and the big shims on the nbacks of the pads add sponginess to the pedal feel. well im going to have to fit them, if there not there, as the Knocking noise is terrible. and driving me Mad Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2010 Share Posted August 24, 2010 Is it from both sides bud? Front and rear or just the fronts? Knocking would worry me slightly. How loud is it? Is it a proper thunk or is it more like a ticking knock? Does it stop with the lightest of touches? Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 Is it from both sides bud? Front and rear or just the fronts? Knocking would worry me slightly. How loud is it? Is it a proper thunk or is it more like a ticking knock? Does it stop with the lightest of touches? just the fronts dude from both sides, its not loud but i can here it with window down. more as if something is loose clunk and moving about. goes away straight away when the brakes are engaged, so right foot on go faster pedal, left foot on brake, noise goes away, soon as its released comes back Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2010 Share Posted August 24, 2010 Ahh that sounds a lot less worrying then As suggested sounds like one of the shims is missing. I didn't know there was a specific anti-knock one. I don't even have the anti-squeal in and I get nothing from them. Must be lucky. Link to comment Share on other sites More sharing options...
monsween Posted August 24, 2010 Share Posted August 24, 2010 bet its still quieter than my brakes Link to comment Share on other sites More sharing options...
Geo Posted August 24, 2010 Author Share Posted August 24, 2010 bet its still quieter than my brakes haha yeah that was giving off some noise when i passed you. that disk will be well and truly gubbed now, least you have a nice new UK setup now, Didnt you buy rears the other day also? Link to comment Share on other sites More sharing options...
monsween Posted August 24, 2010 Share Posted August 24, 2010 Yea, but i mentioned if i could get a set quicker i would and the fella was quite happy with that. Link to comment Share on other sites More sharing options...
Rich8v Posted August 24, 2010 Share Posted August 24, 2010 does it go away when the brakes are engaged dude?? must be something simple Yeah, doesn't matter how i'm driving (fast/slow) as soon as I tap the brakes I get 1 knock where something has moved and then nothing until i use the brakes again. Although I'm pretty sure my knock is on the drivers side only. I had the brakes off recently, and the knock wasnt there before. When i took the calipers off, I left the brake shoes on and didnt take it apart, so I cant see whats changed. I will have a look at my brake set up when I change my brakes. Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2010 Share Posted August 24, 2010 Yeah, doesn't matter how i'm driving (fast/slow) as soon as I tap the brakes I get 1 knock where something has moved and then nothing until i use the brakes again. Although I'm pretty sure my knock is on the drivers side only. I had the brakes off recently, and the knock wasnt there before. When i took the calipers off, I left the brake shoes on and didnt take it apart, so I cant see whats changed. I will have a look at my brake set up when I change my brakes. That sounds more like a suspension knock than what Geo is experiencing. Link to comment Share on other sites More sharing options...
Rich8v Posted August 25, 2010 Share Posted August 25, 2010 That sounds more like a suspension knock than what Geo is experiencing. I'm not to sure. I can understand the weight of the car shifting to the front under braking causing a suspension knock. Bit if I lightly tap the brakes enough to engage them but not affect the car it still knocks. Problem is though. I've had all the suspension arms off the car so will still have to check everything. But I'm 90% sure its the brakes knocking. Link to comment Share on other sites More sharing options...
Guigsy Posted August 25, 2010 Share Posted August 25, 2010 mine does the same. but they only knock when i apply the brakes in reverse. lol Link to comment Share on other sites More sharing options...
L18msy Posted August 25, 2010 Share Posted August 25, 2010 mine does the same. but they only knock when i apply the brakes in reverse. lol Same here. Must be the pads moving a bit. Just turn the stereo up. Link to comment Share on other sites More sharing options...
Suprab1 Posted August 25, 2010 Share Posted August 25, 2010 Yeah, doesn't matter how i'm driving (fast/slow) as soon as I tap the brakes I get 1 knock where something has moved and then nothing until i use the brakes again. Although I'm pretty sure my knock is on the drivers side only. I had the brakes off recently, and the knock wasnt there before. When i took the calipers off, I left the brake shoes on and didnt take it apart, so I cant see whats changed. I will have a look at my brake set up when I change my brakes. I'm getting this in the evo aswell & don't know whats causing it. Link to comment Share on other sites More sharing options...
Geo Posted August 29, 2010 Author Share Posted August 29, 2010 (edited) Video now on First page Guys, As Mr Wilson said looks like the Anti Knock Clips are missing, just need to Confirm. p.S AS SOON AS YOU TUBE LOADS IT. cheers Edited August 29, 2010 by Geo (see edit history) Link to comment Share on other sites More sharing options...
2soops Posted August 29, 2010 Share Posted August 29, 2010 On my g/f's MR2 the holes in the rear disk are very slightly larger than the wheel studs. Therefore the first time you use them after going from reverse to forward or forward to reverse the whole disk and wheel moves either back or forward hitting the studs causing a loud clunk. Dosent seem to bother it as its been like it for years now. Chris is right about the other shims and retainers though, they will definately make it rattly without them. If you read this Chris, is it a noticable sponginess you get with shims as im putting uk's on mine all round and am thinking of maybe leaving the shims out now. Link to comment Share on other sites More sharing options...
