SteveR Posted June 9, 2005 Share Posted June 9, 2005 Just a quick straw poll; 1) Do you drive a NA/TT/Single turbo? 2) How high do you rev the engine before changing up during 'normal' driving? 3) As above but during 'spirited' driving/track driving/similar? I'm curious, that's all. Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 9, 2005 Author Share Posted June 9, 2005 Guess I'm talking about manuals only here (unless you auto guys & girls use manual mode and it lets you rev as high as you want to?) Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 9, 2005 Share Posted June 9, 2005 Single turbo, 7500 rpm Quote Link to comment Share on other sites More sharing options...
AJI Posted June 9, 2005 Share Posted June 9, 2005 in mine on a 'sprited' drive I change just after 5500 because the torque curve tends to drop off rapidly after 5k rpm. Quote Link to comment Share on other sites More sharing options...
hogmaw Posted June 9, 2005 Share Posted June 9, 2005 In my auto I managed to get 110mph in 2nd gear before the automatic cut out thingy happened, that was well into the red. I forgot I was in 2nd I thought I was in D. Duh... Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 Just a quick straw poll; 1) Do you drive a NA/TT/Single turbo? 2) How high do you rev the engine before changing up during 'normal' driving? 3) As above but during 'spirited' driving/track driving/similar? I'm curious, that's all. 1) Jap TT 6sp 2) windows up aprox 2k-3k rpm, windows down a lot more 3) all the way as far as poss before rev limit - 7,200 rpm* *Question for you drap strip experts is this the best/peak power or should i be changing earlier? My understanding is peak bhp my be about 6,500rpm but surely if you leave it longer when you change gear you'll be that much higher on the rpm on the next gear and hence keeping the power going. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 9, 2005 Share Posted June 9, 2005 1) Jap TT 6sp 2) windows up aprox 2k-3k rpm, windows down a lot more 3) all the way as far as poss before rev limit - 7,200 rpm* *Question for you drap strip experts is this the best/peak power or should i be changing earlier? My understanding is peak bhp my be about 6,500rpm but surely if you leave it longer when you change gear you'll be that much higher on the rpm on the next gear and hence keeping the power going. Probably change up at the end of your power band, and you should be in your power band in the next gear still ( dependant on choice of turbo), but you also need to weigh up the pro's of changing gear just before you cross the line, say from 4th Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 9, 2005 Share Posted June 9, 2005 Change up between 2000 and 2500 for traffic driving, 3500 to 4000 for reasonable acceleration, 6000-6500 for hooning. Rev limiter is at 6850 hiss boo. -Ian Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 Probably change up at the end of your power band, and you should be in your power band in the next gear still ( dependant on choice of turbo), but you also need to weigh up the pro's of changing gear just before you cross the line, say from 4th Ha ha cross the line in 5th ! in my dreams. the last time i went santa pods i did a 13.4 @ 106 mph running at 1 bar with both cats in. I've since decatted it so hoping may squeeze another 2-3 mph out of her but nowhere near 5th gear i'm affraid. Quote Link to comment Share on other sites More sharing options...
SkyJawa Posted June 9, 2005 Share Posted June 9, 2005 1) Twin Turbo 2) 6.5-7k rpm 3) 8k rpm Quote Link to comment Share on other sites More sharing options...
stevie_b Posted June 9, 2005 Share Posted June 9, 2005 1) NA 2) Normal driving: 3000 3) Hooning: 6000 Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 Change up between 2000 and 2500 for traffic driving, 3500 to 4000 for reasonable acceleration, 6000-6500 for hooning. Rev limiter is at 6850 hiss boo. -Ian do you have an auto, cos my 6sp hits rev limit well into the red about 7,200 -could my rev counter be incorrect ? Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 9, 2005 Share Posted June 9, 2005 do you have an auto, cos my 6sp hits rev limit well into the red about 7,200 -could my rev counter be incorrect ? yeah the stock one reads high Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 9, 2005 Share Posted June 9, 2005 do you have an auto, cos my 6sp hits rev limit well into the red about 7,200 -could my rev counter be incorrect ? You been reading J-Tuner? Check out my avatar lol This is from datalogs off the E-Manage - the RPMs never go above 6850, they hit the limiter at that point. I have to change into 5th, 4th tops out at 115mph I need a UK spec diff and a 7200rpm rev limit like the VVTi's -Ian Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 You been reading J-Tuner? Check out my avatar lol This is from datalogs off the E-Manage - the RPMs never go above 6850, they hit the limiter at that point. I have to change into 5th, 4th tops out at 115mph I need a UK spec diff and a 7200rpm rev limit like the VVTi's -Ian oh yeah I remember reading the thread about the miss print in the mag Thats interesting you say that about the slip diff as i had a problem with the car a while back and when it was up on the ramps, the mechanic said the slip diff wasn't the standard Toyota one and was infact an after market one. I can defenately get more than 120 mph out of 4th and it defenately revs passed 7,000 rpm but the speedo and rev counter could be well out as Terry S said. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 9, 2005 Share Posted June 9, 2005 yeah speedo reads high too unless you have a certain sized rear tyre Quote Link to comment Share on other sites More sharing options...
Ian C Posted June 9, 2005 Share Posted June 9, 2005 You'll hit 121mph in 4th at 6850rpm with a V160 gearbox and a UK spec diff -Ian Quote Link to comment Share on other sites More sharing options...
Alex Posted June 9, 2005 Share Posted June 9, 2005 J-spec/manual/V161 2-3-500 normal 4-5500spirited ~6500 gunning it....though it's all a bit of a blur so I could be doing any RPM... On the 1/4 I shouldn't need to shift into 5th thanks to the V161's longer 1st, 2nd, 3rd and 4th. (5th is 1:1 like the V160 and 6th is slightly shorter giving a lower topspeed.) Quote Link to comment Share on other sites More sharing options...
TLicense Posted June 9, 2005 Share Posted June 9, 2005 1)TT 2)6K ish 3)I try to shift around 7K. As when I shift it drops me nicely into the high torque area, which I quite like. I have set my shift light to come on at different revs to take account of my reaction time. eg 1-2 shift light comes on about 5800. By the time I notice it and shift it's knocking on the door of 6800. 2nd is more like 6000, 3rd is more like 6300, 4th 6600, 5th and 6th light up at 7000. Rev limit is set to soft cut at 7200 and hard cut at 7500. I've had it soft cut in 6th, on me on the way back from the Nurburgring. Hopefully by having the shift light progressively turn on later and later should stop me hit the rev limit in 1st,2nd and 3rd at Pod like I did when I went there last year. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 1)TT 2)6K ish 3)I try to shift around 7K. As when I shift it drops me nicely into the high torque area, which I quite like. I have set my shift light to come on at different revs to take account of my reaction time. eg 1-2 shift light comes on about 5800. By the time I notice it and shift it's knocking on the door of 6800. 2nd is more like 6000, 3rd is more like 6300, 4th 6600, 5th and 6th light up at 7000. Rev limit is set to soft cut at 7200 and hard cut at 7500. I've had it soft cut in 6th, on me on the way back from the Nurburgring. Hopefully by having the shift light progressively turn on later and later should stop me hit the rev limit in 1st,2nd and 3rd at Pod like I did when I went there last year. christ 7,200 rpm in 6th what speed was you doing ? Quote Link to comment Share on other sites More sharing options...
tbourner Posted June 9, 2005 Share Posted June 9, 2005 tt6 normally as low as possible, not even boosting. Gunning I change at 6300 ish for performance, 7200 ish if I want flames!!! Quote Link to comment Share on other sites More sharing options...
TLicense Posted June 9, 2005 Share Posted June 9, 2005 christ 7,200 rpm in 6th what speed was you doing ? Not as fast as you think. I've got a J-spec auto diff. The needle was a L-O-N-G way off the clock though (So more than 180), but it reads 20% high because of the auto diff gearing throws everything out. Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted June 9, 2005 Share Posted June 9, 2005 Not as fast as you think. I've got a J-spec auto diff. The needle was a L-O-N-G way off the clock though (So more than 180), but it reads 20% high because of the auto diff gearing throws everything out. one word......wow ! I bet you could see the fuel needle move off the clock as fast too Quote Link to comment Share on other sites More sharing options...
SteveR Posted June 9, 2005 Author Share Posted June 9, 2005 Interesting answers, cheers all. Quote Link to comment Share on other sites More sharing options...
