Peter P Posted August 23, 2010 Share Posted August 23, 2010 Hey Guys, Did have a quick look round but couldn't see anything on this topic I promise! I recently picked up a low mileage set of HKS cams which I need to store for a while until I get my next Supe. They are currently in the original HKS boxes and have some surface oil from where they were in use but do I need to do anything more to them to prevent any rust or damage? Any advice appreciated. Cheers. Pete Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 23, 2010 Share Posted August 23, 2010 Keep them in a sealed plastic bag with a bit of engine oil or grease in, as long as theres no exposed bare metal you'll be fine Quote Link to comment Share on other sites More sharing options...
ronttuk Posted August 23, 2010 Share Posted August 23, 2010 i would cover them in grease wrap in paper and put them away in a dry place for storage Quote Link to comment Share on other sites More sharing options...
Peter P Posted August 23, 2010 Author Share Posted August 23, 2010 Cheers for the info fellas! Will get them in some oil and wrapped up somewhere safe. Thanks again. Pete Quote Link to comment Share on other sites More sharing options...
SPG Posted August 28, 2010 Share Posted August 28, 2010 I could keep them safe for you in my engine for a nominal fee if you like Quote Link to comment Share on other sites More sharing options...
Peter P Posted August 28, 2010 Author Share Posted August 28, 2010 I could keep them safe for you in my engine for a nominal fee if you like Lol. Thanks for the kind offer fella but somehow think I'd struggle getting them back again! suppose you'd look after the HKS cam pulleys as well for me?! For a nominal fee of course!! Pete:) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 29, 2010 Share Posted August 29, 2010 Wash them off with brake cleaner thoroughly, then air dry and cover in clean fresh grease unless you want to splash out on Rocol aerosols of preservative stuff? The reason to remove old oil is if it is OLD it will be corrosive due to combustion contaminants and maybe moisture. BE SURE NOT TO DROP OR KNOCK cast iron cams (which is what they are) as they snap or shatter VERY EASILY!!!! I pack them in very heavy walled cardboard tubes that I pick up from carpet places, or in plastic pipe with caps on if they are precious / expensive. HTH. Quote Link to comment Share on other sites More sharing options...
