airiel hole gromit
dr_jekyll
I'd say you'll struggle to find something that fits properly given the shape Craig, if you're not bothered too much about appearance you could cut a bit of rubber to shape (not sure where you'd get some rubber :D) paint it and stick it on with some silicone. Alternatively Steve's got the stubby aerial group buy going on you could jump in there for £50.
Weld a plate in mate, it will be the only way some arse does not push the grommet through.
the car wont be left on the road atall now and im not over botherd about looks as this car is just going to ba a track car now and liv in the garage. i mite melt some rubber and see what i can make :)
Yeh.....mine had masking tape over the aerial, 3rd brake light and the spoiler holes at the pod:d:d
I just have a slightly larger grommit in mine...looks ok
I meant something a bit less obvious:d black insulation tape or black race tape.
If its a track car i really wouldn't go shoving filler on it as it'll crack and fall out ;)
i despoilered mine using fibreglass from the rear, grind the metal surroundings down from the front, fibre filler over the top, sanded it and skimmed it with filler..job done, no need for this welding business costs to much and will probably rust over if its not treated properly.
