supra steveo Posted August 19, 2010 Share Posted August 19, 2010 (edited) this is a guide of how to fit your stubby conversion aerial firstly this is how the oem aerial should look on the car with the mast down first thing you need to do is remove the locking nut like so , use a hammer and screwdriver with car to undo if tight remembering to hit forward away from car so you dont damage your paintwork then remove the black rubber grommet, it is very important you do NOT throw this bit away you are going to need it you then need to remove the boot plastics so you can see the electric motor that makes the mast go up and down pull out the little drain from the floor and using a 10mm socket undo the bolt that holds the motor housing to the body of the car now you can remove the assembly from being fitted to the car unplug the coax cable that goes to your radio and unclip the power for the mast motor you should now be left with the back of the car looking like this now thats removed get your stubby aerial kit and it should look like this when you add your rubber grommet to the kit this how the extension bar now goes together this picture shows the bracket fitted now the bracket is fitted you should be able to see the top of the bracket i.e. the bit the extension bar goes through now put the extension bar throught the hole in the car body and the top of the bracket, then fit the large nut to extension bar and tighten, if its a pain to do undo the 10mm bolt at the bottom of the bracket so the extension is free to hang and move so you can get the big nut to bite on the extension bar as soon as the nut is on put the 10mm nut back in to hold the extension bar in place and the nut basically pulls the extension bar in to the car making the grommet seal nicley against the body of the car now all thats left to do is fit the amplified antenna base to the bottom of the extension bar , now this is where the difference is to the Mk 1. there is now no stress to the fixing on the amplified base , now fit the the inline amplifier that should give an extra bit of boost ( everyone likes boost ) twist the two red wires together and if you run a bit of wire form the IGN live from the back of your stereo to the two red wires that are joined together this should provide enough power to the amplifiers any dramas PM me Edited November 27, 2013 by supra steveo (see edit history) Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 (edited) ............... edited due to the Mk 2 stubby kit Edited November 27, 2013 by supra steveo (see edit history) Quote Link to comment Share on other sites More sharing options...
Matt H Posted August 19, 2010 Share Posted August 19, 2010 Good stuff mate. I was wondering when this would surface. No ideas on connecting the power up? Quote Link to comment Share on other sites More sharing options...
Wyntersun Posted August 19, 2010 Share Posted August 19, 2010 What's the red wire for? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 (edited) HINTS * get some wire and either solder or bullet conector it to the red wire then feed it to the ignition power wire behind your stereo , the set up doesnt really need it but if you feel you want to do the job 110% then thats what you can do * use a little bit of rubber sealant around the where the grommet meets the car ( make sure its out of sight tho ) and where the extension bar meets the top of the grommet Edited August 19, 2010 by supra steveo (see edit history) Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 What's the red wire for? its a power wire for the amplified antenna base Good stuff mate. I was wondering when this would surface. No ideas on connecting the power up? i would connect it to the ignition wire behind the stereo bud Quote Link to comment Share on other sites More sharing options...
Rummy Posted August 19, 2010 Share Posted August 19, 2010 http://img.photobucket.com/albums/v489/suprastevo/Ethan/b13bd245.jpg all thats left to do is list your old oem aerial and motor minus the black grommet on ebay ....and get some new lower boot rubbers Quote Link to comment Share on other sites More sharing options...
Matt H Posted August 19, 2010 Share Posted August 19, 2010 i would connect it to the ignition wire behind the stereo bud Sounds Quote Link to comment Share on other sites More sharing options...
Jamesy Posted August 19, 2010 Share Posted August 19, 2010 cheers mate Quote Link to comment Share on other sites More sharing options...
johnny g Posted August 19, 2010 Share Posted August 19, 2010 What about the power lead going to the aerial to power that? No good? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 ....and get some new lower boot rubbers next on the job list fella Quote Link to comment Share on other sites More sharing options...
Supralad Posted August 19, 2010 Share Posted August 19, 2010 So do you have to connect the red wire to anything? and the power lead is not reused? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 What about the power lead going to the aerial to power that? No good? I dont have a power meter so cant check to see if that sends 12 volts constantly, if any one does have a power meter and can confirm that it does, and that the negitive not being connected is ok then it should be good to run off that wire too Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 19, 2010 Author Share Posted August 19, 2010 So do you have to connect the red wire to anything? and the power lead is not reused? you dont need it to be honest , but if you want to have that piece of mind that its connected then its up to you Quote Link to comment Share on other sites More sharing options...
jazz1 Posted September 13, 2010 Share Posted September 13, 2010 Got mine today can't wait to fit it thank you very much mate Quote Link to comment Share on other sites More sharing options...
neo2810 Posted September 13, 2010 Share Posted September 13, 2010 I can confirm that the radio reception is absolutely fine just with aerial connected. There is no need to run the booster so ignore the red wire. Quote Link to comment Share on other sites More sharing options...
Guest JonnyD Posted September 13, 2010 Share Posted September 13, 2010 Hello do you have a parts list for this or have you made the extension and bracket yourself ? cheers Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 13, 2010 Author Share Posted September 13, 2010 this was made Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 13, 2010 Author Share Posted September 13, 2010 I can confirm that the radio reception is absolutely fine just with aerial connected. There is no need to run the booster so ignore the red wire. another little tip , to stop some wee shite or chav running off with your stubby use some loctite threadlocker Quote Link to comment Share on other sites More sharing options...
neo2810 Posted September 13, 2010 Share Posted September 13, 2010 another little tip , to stop some wee $#@!e or chav running off with your stubby use some loctite threadlocker ....or use the red wire to rig up an elaborate electrocution solution to fry the f*ckers if they try.... Quote Link to comment Share on other sites More sharing options...
Guest JonnyD Posted September 14, 2010 Share Posted September 14, 2010 this was made Cheers Quote Link to comment Share on other sites More sharing options...
jazz1 Posted September 14, 2010 Share Posted September 14, 2010 Lol no one will steel mine I'm always with my supra when I drive it Quote Link to comment Share on other sites More sharing options...
neo2810 Posted September 14, 2010 Share Posted September 14, 2010 Lol no one will steel mine I'm always with my supra when I drive it What? You mean you haven't had the autopilot mod installed? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 14, 2010 Author Share Posted September 14, 2010 Lol no one will steel mine I'm always with my supra when I drive it well round my kneck of the woods the is a certain estate where the kids will try and nick ya wheels as you drive through the place Quote Link to comment Share on other sites More sharing options...
Lee P Posted September 15, 2010 Share Posted September 15, 2010 Yes you can connect to the feed (red) that's already in the boot for the electric aerial. It's mainly for mw reception but worth doing. The reception won't be great as the mast is too short for a supra. Quote Link to comment Share on other sites More sharing options...
