JohnK Posted June 8, 2005 Share Posted June 8, 2005 This is on a renault 18, 1.7 carb. The car has always ran on after the ignition was switched off, sometimes (very roughly) for a couple of minutes! I put this down to a carb problem as the carb seemed buggered, the mixture screw did nothing when turnt (co meter) and as far as I can see the timing is fixed. Fitted a (brand)new carb, now the mixture screw works, although it doesnt give the adjustment I would expect and at first the running on stopped. The new carb also has a 12v ignition switched solonoid to stop running on, however it has started doing so again, not as bad as before but doing it all the same. Anyone have any ideas how I can stop this. Link to comment Share on other sites More sharing options...
Toms Supra Posted June 8, 2005 Share Posted June 8, 2005 Timing does this as well if its too advanced. Check the timing. Link to comment Share on other sites More sharing options...
JohnK Posted June 8, 2005 Author Share Posted June 8, 2005 as far as I can see the timing is fixed. The dizzy appears fixed so I guess the timeing is. Link to comment Share on other sites More sharing options...
fredm Posted June 9, 2005 Share Posted June 9, 2005 Try disconnecting the wire to the stop solenoid on the carb whith the engine running, if the engine does not stop you have found the problem. Link to comment Share on other sites More sharing options...
Supragal Posted June 14, 2005 Share Posted June 14, 2005 Automatic or manual choke? Link to comment Share on other sites More sharing options...
JohnK Posted June 14, 2005 Author Share Posted June 14, 2005 Manual Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 15, 2005 Share Posted June 15, 2005 Don't let it run on, VERY bad for an engine, put it in gear and stall it on the clutch. Old Morris Itals, MGB's and other BMC B series engined cars had an anti run on solenoid that allowed a massive inlet air leak when switched off. You could adapt one of those. I think Renault do a thick head gasket to drop the compression, this helps stop it, too. Link to comment Share on other sites More sharing options...
