Seibon TS Bonnet Fouling on Fan Shrowd
SupraJames
Just wondering if anyone else with a Seibon TS Style Bonnet has had any issues with it fouling the fan shrowd as mine is hitting and not sure what to do you. Had a few issues but sorted most of the them, bonnet pinds needed to be cut down as would not fit behind UK light due to the adjuster motors. The bonnet clears my Greddy strut brace no probs, but is hitting on the shrowd, one solution would be edit the vent that is hitting and take off some of the height/angle of the vent, then just need to mod the hinges to take the lifters. Dont want to remove the shrowd as being a UK spec when I did this once before I had a problem with oil temp.
Any ideas..?
Thanks
Only way to do it if you want to keep the bonnet iscto trim the shroud. I had to do the very same thing with bosscos supra abs a TRD bonnet. Get yourself an angle grinder and sone polyfan discs and very gently start removing material. Don't push too hard cos these discs will tear through your bonnet very quickly.
Out of curiosity can you weigh the new and the original bonnets please?
i Had a seibon carbon fibre bonnet on my supra. when i weighed it there was only 1-2kg diffrents between the cf and stock. i also had one repleca TRD cf from envyperformance aswell and that weighed more then stock with a real bad fit to so that went back. The seibon boot lid is lighter by about 8kg.
