Replacing a rear hub - grease?
Homer
Hopefully a simple question, in the attached picture should I be adding any grease around the bearing area before installing the driveshaft?
Additionally, which grease should be used around the spines itself - if so, would that be copper slip? Strangely the service manual makes no mention of using any grease or copper slip anywhere in the assembly section of the rear hub.
In theory the bearing shpuldn't come apart, it's a press fit so there shouldn't be anything to put grease into. If it has dirt in there try and wash/wipe out whats there and that should do fine mate.
Cheers Graham, the grease looks pretty dirty, so should that be picked out? Should any be added back though? If so what type of grease?
Edit - no chance of it coming apart, it's all secured in there with the clips and seals in place.
