Bulldogge Posted August 17, 2010 Share Posted August 17, 2010 i had strip out my Supra. Last time i start the engine 3 weeks ago... and it had works well. Since that i had remove the electric box under the Driver Seat. I also removed the seat belts, and the electric wiring from the rear window ... but it wasnt connected near the radio ... now i have the problem that the car dont starts... i dont maybe a wire isnt connected well.. or maybe its because of the removed box or the removed belts... is it possible? here a pic of the box Link to comment Share on other sites More sharing options...
Wez Posted August 17, 2010 Share Posted August 17, 2010 No idea what it is but I also removed one from my car a long time ago when stripping the interior Link to comment Share on other sites More sharing options...
Rich8v Posted August 17, 2010 Share Posted August 17, 2010 I bet that's something to do with the alarm. Did the wiring that goes to it look standard? Link to comment Share on other sites More sharing options...
Dnk Posted August 17, 2010 Share Posted August 17, 2010 Try plugging the box back in and see what happens Link to comment Share on other sites More sharing options...
Bulldogge Posted August 17, 2010 Author Share Posted August 17, 2010 yes its stock wiring... the problem is... i already had remove it... and some more things... and i dont know why the engine now dont starts Link to comment Share on other sites More sharing options...
JustGav Posted August 17, 2010 Share Posted August 17, 2010 I'm suspect that box might be the keyless central locking.... I'd check all your wiring and fuses as I'm 99% sure that unit would not be responsible for the car not starting. Link to comment Share on other sites More sharing options...
Wez Posted August 17, 2010 Share Posted August 17, 2010 Mine wasnt connected to anything anyway Link to comment Share on other sites More sharing options...
Dnk Posted August 17, 2010 Share Posted August 17, 2010 yes its stock wiring... the problem is... i already had remove it... and some more things... and i dont know why the engine now dont starts Retrace your steps and refit parts until the car works, if it still doesn't work then its something else. Does the engine turn over ? What other parts have you removed other than what you have mentioned already ? Link to comment Share on other sites More sharing options...
Bulldogge Posted August 17, 2010 Author Share Posted August 17, 2010 the starter works... but the engine doesnt start.... we also tried with a new battery, and start spray... i can smell fuel... so i guess there is no spark ... i also have a alarm by clifford ... but never had problem with it. what i remember is only the box... the safety belts ... and the rear window (lower part) what wasnt connected... by these all parts i guess it can be only the box... or maybe i unscrew something what i forgot... or i get a different problem by bad luck.... so box is connected with 5 or 6 cables ... under the steering ... on the right side.. Link to comment Share on other sites More sharing options...
Bulldogge Posted August 18, 2010 Author Share Posted August 18, 2010 hmmm-.-- no answer? Link to comment Share on other sites More sharing options...
Dnk Posted August 18, 2010 Share Posted August 18, 2010 Have you got a spark at the plugs or not ? guessing really isnt the way forward Have you reconected the box just to rule it out along with anything else you disconected Link to comment Share on other sites More sharing options...
Rich8v Posted August 18, 2010 Share Posted August 18, 2010 As Dnk has said, plug the box back in. I still think it could be an old alarm module that hasn't been properly removed, so the car is immobilized and won't start. Link to comment Share on other sites More sharing options...
mobius Posted August 18, 2010 Share Posted August 18, 2010 I have the same box and connector under my drivers seat, thought it was something to do with the electric seat Link to comment Share on other sites More sharing options...
Bulldogge Posted August 23, 2010 Author Share Posted August 23, 2010 i install it today back... and voila... the engine starts again.... does anyone have a electric wiring diagram? i want to remove the box.. so i have to bridge it out ... Link to comment Share on other sites More sharing options...
Spike3.0 Posted August 23, 2010 Share Posted August 23, 2010 I have that same box too Link to comment Share on other sites More sharing options...
Wez Posted August 23, 2010 Share Posted August 23, 2010 It must be something to do with an old alarm or imob then as mine works fine without it Link to comment Share on other sites More sharing options...
Dnk Posted August 24, 2010 Share Posted August 24, 2010 i install it today back... and voila... the engine starts again.... does anyone have a electric wiring diagram? i want to remove the box.. so i have to bridge it out ... I rest my case Link to comment Share on other sites More sharing options...
Jellybean Posted August 24, 2010 Share Posted August 24, 2010 Try here , sorry can t acess in work http://supras-ireland.net/manuals/Workshop%20Manuals/Supra%20MK4/ Link to comment Share on other sites More sharing options...
scotty71 Posted August 24, 2010 Share Posted August 24, 2010 I rest my case always good advice from "the older members" its not because dnk is smart its because he has been around so dam long and has seen this issue before Link to comment Share on other sites More sharing options...
jackso11 Posted August 24, 2010 Share Posted August 24, 2010 Its the original central locking, probably has an immobilizer built in. Link to comment Share on other sites More sharing options...
Wez Posted August 24, 2010 Share Posted August 24, 2010 Its the original central locking, probably has an immobilizer built in. Central locking control is done by another box which is tucked up by the lower glovebox, with this box removed my central locking still worked Link to comment Share on other sites More sharing options...
jackso11 Posted August 24, 2010 Share Posted August 24, 2010 Central locking control is done by another box which is tucked up by the lower glovebox, with this box removed my central locking still worked Is your central locking the stock toyota locking? or one that is controlled by the button on your alarm fob.. Link to comment Share on other sites More sharing options...
Wez Posted August 24, 2010 Share Posted August 24, 2010 Is your central locking the stock toyota locking? or one that is controlled by the button on your alarm fob.. Controlled by an aftermarket alarm fob. Link to comment Share on other sites More sharing options...
jackso11 Posted August 24, 2010 Share Posted August 24, 2010 Your aftermarket fob signal will be received by the new alarm box somewhere else in the car which will send the message to your central locking actuators in the doors to lock and unlock. This box will be for the original central locking mounted in the key. I have 2 buttons on my key that would send a signal to this black box, my black box is long gone though along with the rubber bits from my buttons I assume the box must also have an immobilizer build in so kills your engine when you take it out. No idea how to bypass it though. Ask mattharwood, he will know. Maybe Heckler knows too. Link to comment Share on other sites More sharing options...
Wez Posted August 24, 2010 Share Posted August 24, 2010 This is the door control unit near the lower glovebox. Link to comment Share on other sites More sharing options...
