Ignition source in fuse box
jevansio
After the relay controlling my electric fans gave up at SupraPod, I've decided to do a proper job and put everything in the fusebox.
I've found a spare relay slot, got a spare headlight relay, and got the terminals for underneath.
So rather than running an ignition feed from behind the dash (which is the way I currently do it), is there an ignition feed in the fusebox? I'm guessing the EFI Main relay would be a good source? Both EFI Main & EFI 2 have a 12v supply when ignition is switched on?
Edited by jevansio (see edit history)
maybe use 2 relays aswell or a higher amp relay because of the draw on start up??
glad you got back ok and the fuse helped
Pretty sure one will do bud, I don't think adding extra relays achives anything anyway (unless you're running one fan per relay).
Cheers mate, yeah it was perfect all the way home :D
Well this is the fruits of these questions, my electric fans are now fused & relayed in the fusebox.
I took apart an MR2 fusebox & used the connectors underneath to make the spare relay slot work and the TEL fuse :). Nice & tiday and no chance of the relay getting wet now :)
Used a spare headlamp relay which swicthes 2 x 15amp headlight circuits, so should be OK for my 1 x 30amp fan circuit?
I managed to blow my 120amp fuse in the process like, when I had the fuse box apart checking for what was 12v the bottom touched the shell and it popped, bloody £13 from Toyota!!!!
