Internal coatings
JustGav
Been doing a bit of research into this and there seems to be mixed opinions.
Currently looking at building a purpose built NA-T block, with TT pistons, matched CC that sort of thing. There are a few coatings available from techline, and just wondering if it is worth the hype?
Thinking about the following...
Head internal coating, piston surface coating, crown coating, valve coating and exhaust internal and external coating.
http://www.camcoat.com/main/dfl/
i suspect you would end up with some very pretty pistons, a big bill and not much else
can you do a project thread on this as i am going to be doing a similar build with tt pistons, i had already started but i found defects with the block i had so had to abon , but i will be doing it when i get another block so would love to see haw you do things.
Yeah, I'd be happy to do that... I'm not going to be the primary builder however as that is more Graham S's department. Let me have a word with him and once I've got the workshop prep'ed for a clean room build.
