StuartW Posted September 29, 2010 Share Posted September 29, 2010 Stu i was going to ask about grip .... at the moment i get absolutley zero on the road after about half throttle. If i drag race with this set up am i likely to just be left on the line with spinning wheels?? The track is sprayed with a sticky glue, Sometimes during prize giving @ the pod with the sun out you can hardly lift your feet as they adhere:) Tyre pressures can be dropped to the verge of the trye slipping on the rim, between 8-14psi, depending on rim size and tyre height. Mark the tyre to rim with tipp ex to see if you get slip. Softest rear suspension, You could also adjust the rear camber to square the wheels up to the strip surface, If you do this the toe should be checked too. Because you have Independent rear suspension the wheels will go in at the top under suspension compression and so lessen the surface area of the tyre tread pattern. Hope that helps Quote Link to comment Share on other sites More sharing options...
Jamesy Posted September 29, 2010 Share Posted September 29, 2010 yep very helpful mate thank you Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 2, 2010 Author Share Posted October 2, 2010 Sorry guys, i know its a bad show to drop out but i need to get the car ready for thunder road and i dont have time to do both events. 1. JamieP 2. Josh 3. mark newman 4. little num 5. GazB 6. Guigsy 7. richarde7927 8. Scotty71 9. dr_jekyll 10. Neil-NA 11. Ricky49 (if single is finished) 12.bradh 13. karl 14. StuartW 15. Fitz 16. Shima60 (If single is finished) 17. Steady dave 18. scottc998 (Spectating) 19. kill1308 (Spectating) 20. Ganty 21. antony lacey (spectating) 22. supramanuk 23. wilkorangerover 24. supra tom 25. mach man 26. tom tt Quote Link to comment Share on other sites More sharing options...
Josh Posted October 6, 2010 Share Posted October 6, 2010 Is everyone else still going? If the weather's going to be ok I'll still be there to watch Quote Link to comment Share on other sites More sharing options...
scotty71 Posted October 6, 2010 Share Posted October 6, 2010 Im still going with HD cams at the ready Quote Link to comment Share on other sites More sharing options...
GazB Posted October 6, 2010 Share Posted October 6, 2010 Is everyone else still going? If the weather's going to be ok I'll still be there to watch I'm still planning on being there for the weekend, should get there friday night and set up camp in pit area ready for saturday test and tune before race day on sunday I shall be looking at weather forecast before going Quote Link to comment Share on other sites More sharing options...
Josh Posted October 6, 2010 Share Posted October 6, 2010 I'll probably just go on the Sunday but if the weather's good for both days I might be tempted to go for the weekend as it's only an hour from me Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 11, 2010 Share Posted October 11, 2010 I'm still going. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 11, 2010 Share Posted October 11, 2010 im all dependant on my brakes , brake fluid, and boost controller arriving and being fitted on time Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 12, 2010 Share Posted October 12, 2010 Weather looks good. Cool crisp and dry so far Sunday, 17 October High 12°C Mostly Sunny Wind From Northwest at 11 kmph Maximum Humidity 70% UV Index 2 Chance of Precip. 0% Avg. High. 13°C Record High N/A Sunrise 07:35 Quote Link to comment Share on other sites More sharing options...
scotty71 Posted October 12, 2010 Share Posted October 12, 2010 Awesome Looking at the wind direction we will be dragging into a headwind... that is my first excuse Quote Link to comment Share on other sites More sharing options...
Josh Posted October 12, 2010 Share Posted October 12, 2010 Weather looks good. Cool crisp and dry so far Sunday, 17 October High 12°C Mostly Sunny Wind From Northwest at 11 kmph Maximum Humidity 70% UV Index 2 Chance of Precip. 0% Avg. High. 13°C Record High N/A Sunrise 07:35 Awesome Looking at the wind direction we will be dragging into a headwind... that is my first excuse Great, looking to be a good day Let's just hope everyone turns up. Good excuse Scotty Quote Link to comment Share on other sites More sharing options...
scotty71 Posted October 12, 2010 Share Posted October 12, 2010 well it looks like the strip runs to NW, so headwind it is..... 11kph might be a couple of seconds off my time Quote Link to comment Share on other sites More sharing options...
Josh Posted October 12, 2010 Share Posted October 12, 2010 well it looks like the strip runs to NW, so headwind it is..... 11kph might be a couple of seconds off my time Haha fair enough, I'll stand behind your car and blow as hard as i can to counteract the wind Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 12, 2010 Share Posted October 12, 2010 The track is sprayed with a sticky glue, Sometimes during prize giving @ the pod with the sun out you can hardly lift your feet as they adhere:) Tyre pressures can be dropped to the verge of the trye slipping on the rim, between 8-14psi, depending on rim size and tyre height. Mark the tyre to rim with tipp ex to see if you get slip. Softest rear suspension, You could also adjust the rear camber to square the wheels up to the strip surface, If you do this the toe should be checked too. Because you have Independent rear suspension the wheels will go in at the top under suspension compression and so lessen the surface area of the tyre tread pattern. Hope that helps I always thought harder rears were better. That way when the car squats it pushes the rears into to Tarmac more. Soft suspension would just make it easier for the wheels to spin. I also thaught the rears of drag cars squat because of the sidewalls squashing not suspension. Am I wrong? Seems a sound theory to me lol Also to remind everyone shakespire need helmets for all runners. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted October 12, 2010 Share Posted October 12, 2010 Yes I need to get a helmet!! Where is the best place to get one.... will not use it much only for the odd drag/track day Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 12, 2010 Share Posted October 12, 2010 I've seen them on eBay quite cheep. If they are any good or not I don't know. I don't recall the shop name tho Quote Link to comment Share on other sites More sharing options...
StuartW Posted October 12, 2010 Share Posted October 12, 2010 I always thought harder rears were better. That way when the car squats it pushes the rears into to Tarmac more. Soft suspension would just make it easier for the wheels to spin. I also thaught the rears of drag cars squat because of the sidewalls squashing not suspension. Am I wrong? Seems a sound theory to me lol Also to remind everyone shakespire need helmets for all runners. The Theory on the tyres is the more softer pressure and compound they are the more surface area of tyre mating to tarmac you get. The idea of soft suspension is to get the body to roll around the wheels and push the CG back onto the driven wheels, They call that "Hook up" In a good launch video'd in slo mo you will see the rears punch down and then the body lurch back to give you a perfect 60ft time Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 12, 2010 Share Posted October 12, 2010 I guess it's not going to make a big difference in times to a bpu car but my rear springs feel like rock Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted October 13, 2010 Share Posted October 13, 2010 Awesome Looking at the wind direction we will be dragging into a headwind... that is my first excuse I like that excuse all ready . you still fancy my car vs your auto bpu vs manual 6 speed bpu . Im still will be coming if the weather is good (no rain ) ill only be there on the sunday . Rich. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted October 13, 2010 Share Posted October 13, 2010 yeah d00d Quote Link to comment Share on other sites More sharing options...
Josh Posted October 13, 2010 Share Posted October 13, 2010 Are most people just going on the Sunday? Might have a drinking day Saturday if it's going to be dead then Looking forward to this! Quote Link to comment Share on other sites More sharing options...
GazB Posted October 13, 2010 Share Posted October 13, 2010 I'm looking at getting there before dark on friday night to get a good pit area for motorhome, trailer and car. Then have a few beers Come over and say hello anybody that visits either saturday or sunday, i'll be running my car both days but will spend time in pit area chilling as well. Who is staying over saturday night? Quote Link to comment Share on other sites More sharing options...
GazB Posted October 15, 2010 Share Posted October 15, 2010 Car is loaded on trailer, motorhome is packed and i'm ready for the off See you at Shakey Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 15, 2010 Author Share Posted October 15, 2010 Im going to come up tomorrow for a few hours i think, cant do sunday. Quote Link to comment Share on other sites More sharing options...
