Dyna Pack (Hub Dyno) Issues?
Jellybean
Got the car checked over today, and after the Dyna pack run, back in July 3rd my hub was loose (rear Drivers Side); it was also the same issue with Jamie on here; his rear bearing(Drivers Side) was gone a day or two after the power run
Is this a common issue? With the Hub Dyno's and the drivers Side rear bearing
I must be one of the lucky ones as ive got silly wheels and my bearings are fine :) perhaps uk spec bearings are just a bit tougher :innocent::D
My cars also been on a hub dyno twice with no problems
same here dunk;no issues; just taught it was weird the drivers side was only affected on the other cars
Possibly coincidence ?
After seeing quite a few stock wheeled cars need wheel bearings im amazed mine are fine and have done over 50k with 11.5" wide rears.
