New uk spec headlights have condensation inside??
Aero-M
toyota have had a problem with these in the last year or so...i would say 60% of them ive had do the same...apparently something to do with a supplier who now make them....ive had some changed over from them and they are the same!
i put it down to poss the sealant they use to seal the glass to the backing...
How annoying would that be, I would take them back !
have done....fitted them, washed the car...clouded up again! i tested a set and put extra sealant around the light and that worked so i put it down to poor sealant they use or not enough coverage?
What is the best sealant to use?
Do you have to split them to reseal them?
  • 3 months later...
So toyota still make parts for the supra? they arnt taken of a shelf and wernt made at the same time as the cars were then?
Check the bulb are seated correctly and have a good seal.
I thought the bulbs were behind glass lenses that are seperate to the main headlamp area where the condensation forms ?
I'd take them back and telll them you want a new pair, their hardly cheap are they.
I did speak to him but would have to buy a new set then return the others and wait for money to be returned. My car came of the road at the end of August and won't be out again until april, so Will wait until I wash it to see if they do it again and change them as it will still be within the year warranty.
