Re calibrating Greddy boost gauge and fitting oil temp/pressure gauges?
p3te
i have Greddy electronic gauges in my car but my boost gauge is reading low. Sits below the 0 and at standard boost it reads 0.5
http://img690.imageshack.us/img690/8969/dsc02212em.th.jpg can these be re calibrated? or is it knackered,
Also I’ve just removed a grex oil cooler from my car which had my oil temp and oil pressure gauges plumbed into the sandwich plate for the filter relocation kit, I’m wanting these plumbed in again so what’s the best way? Tap the block or is there a standard oil pressure/temp feed on the block I can fit these to?
had a look at this today and had no joy :( there’s 2 rubber grommets on the back of the gauge with 2 blue plastic screws underneath, the little movement that was on them made no difference to the needle position, I then looked for the control boxes, small grey box about the size of a cigarette packet but it had no screws on it? Just the 2 plugs? Have I missed something or could there be another way?
peak it shows with a double decat and standard tt catback exhaust
http://img828.imageshack.us/img828/8402/dsc02223m.th.jpg
Edited by p3te (see edit history)
